Blasting Estimate?
Discussion in 'The BS Topic' started by HurtHorseZ28, Jul 28, 2017.
  1. HurtHorseZ28
    HurtHorseZ28 Veteran Member Lifetime Gold Member
    4,529
    Jul 29, 2000
    Philadelphia Area, PA, USA
    I know this can probably go in another topic, but looking for a quick answer. I have a stock set of lower control arms that are rusty and filthy. (They're removed from the car.) Looking to have them cleaned up. What should it cost me to have a shop remove old ball joints/bushings, blast, paint chassis black, and press in new ball joints/bushings. Labor cost only, I supply the parts (except the paint). Thanks!
  2. CorkyE
    10,650
    593
    If you're going to blast A-arms, you're likely going to do some more cleaning on other parts. That said, you can buy a blast cabinet from HF for $179, and rent (free on return) a ball joint press from your local parts store. If you don't have an air compressor, this will be a good excuse to buy one. I realize the initial cost of buying equipment is high, but you can get nickel and dime to death by paying a shop to do small odd jobs. You can also search for and make friends with someone in you area that has the equipment and supply copious amounts of malted beverages, that usually works for me when friends come calling with parts and coolers. IMHO
  3. Shizzle
    Shizzle Veteran Member
    2,698
    714
    Aug 1, 2012
    oak lawn, illinois
    I have the $179 HF blast cabinent, it's a POS. The light sucks, the trigger on the gun routinely sticks, and you have to continuously move the suction tube around and put back pressure on it to clean it out.
    So by the time you upgrade the light and gun, you could've been into a better cabinent, the Eastwood one is a lot nicer IHMO.
    carr911 likes this.
  4. Happy_Dan
    Happy_Dan Veteran Member
    1,040
    247
    Sep 13, 2013
    New Boston, NH
    TP Tools has great blast cabinet equipment. I love mine
  5. carr911
    carr911 Veteran Member
    2,116
    884
    Mar 4, 2016
    Tampa, FL
    Spot On!
  6. CorkyE
    10,650
    593
    Agree on the light but I haven't had issues with gun or pickup tube. Hopefully you haven't jinxed me. :D
  7. Shizzle
    2,698
    714
    Aug 1, 2012
    oak lawn, illinois
    What are you running in it? I do a mixture of sand and black beauty.
  8. CorkyE
    10,650
    593
    Straight black beauty.
  9. Shizzle
    2,698
    714
    Aug 1, 2012
    oak lawn, illinois
    My gloves are trashed already, I had it less than a year.
    The hopper drain I wish was a sliding gate instead of the all or none,though I'm not sure if all are like that
