Blood curdling sound coming from the engine
Discussion in 'Engine Topic' started by ULTM8Z, Feb 19, 2021.
Thread Status:
Not open for further replies.
  1. Dave Nelson
    Dave Nelson Veteran Member
    5,115
    4,075
    Dec 19, 2003
    Vineland N.J USA
    I've heard spun bearings sound like that, hope it's not.
  2. Jodi
    Jodi Veteran Member
    763
    457
    May 22, 2019
    Harmonic balancer...
    sandlapper likes this.
  3. TTR230
    TTR230 Veteran Member
    375
    152
    Aug 1, 2020
    Burlington, Ontario
    Some interesting ideas. Some having potentially better outcomes than others! Watching this thread closely to see what it turns out to be.
  4. sandlapper
    sandlapper Veteran Member
    598
    194
    Oct 9, 2020
    SE CSA
    most Torque Converters have a centered male pilot "nub" which mates into rear of crank ... you'll have to pull TC / trans back a little to decouple. But trans is what holds rear of motor up; without trans OR without support under oil pan w/ wood block & jack, motor'll likely droop and may damage ign distributor.
    Often, flexplates crack around-within center bolt circle pattern; can be difficult to identify in-car. Better to view on bench w/good light.
    let's all hope your noise is something as innocuous $ as cracked flexplate or slipped harmonic balancer.
    :bowtie:
  5. sandlapper
    598
    194
    Oct 9, 2020
    SE CSA
    yup. That could be it as well. Slipping outer ring rubbing on timing cover.
    Quick N easy to verify ... check that First ultimatez.
  6. BonzoHansen
    20,651
    1,746
    Jun 1, 2005
    Scott from Hamilton, NJ
    i've had that happen. it will slice through the timing cover pretty quick. should be rather noticeable.
  7. 1320feet
    1320feet Veteran Member
    315
    126
    Oct 23, 2019
    Calgary, Alberta.
    Is there a chance you over reved it just before this happened? I'm thinking you maybe pinched a rod bearing. What rods are in there?
  8. flht99b
    flht99b Veteran Member Gold Member
    832
    273
    Nov 28, 2014
    Knoxville, TN
    Does the engine run roller lifters? I've heard a similar sounds from a roller lifter that the roller is seizing.
  9. ULTM8Z
    ULTM8Z Veteran Member
    9,879
    784
    May 19, 2000
    Los Angeles
    It's just a factory ZZ4 short block.
  10. ULTM8Z
    9,879
    784
    May 19, 2000
    Los Angeles
    Yep, the factory ZZ4 lifters.
Thread Status:
