Blower fan always runs high
Discussion in 'Troubleshooting & Diagnosis' started by my71bmf, Apr 30, 2021.
  1. my71bmf
    my71bmf Veteran Member
    317
    May 26, 2008
    Tulsa, Ok
    1971 Camaro, just coming out of hibernation so to speak. Regardless of my switch setting, my blower motor stays running as if it were in the high setting. Any ideas what to check? Don't really need full blast heat when it's 80+ degrees.
    TIA.
  2. Jodi
    Jodi Veteran Member
    793
    484
    May 22, 2019
    Its more than likely the resistor went bad, check that one first. Good luck!
    T/A Tom and Zstar like this.
  3. Twisted_Metal
    29,291
    2,257
    The contacts in the relay are probably stuck.
    When the switch is flipped to the High setting, the resistor pack is bypassed.
    my71bmf likes this.
  4. Gary S
    23,812
    1,459
    Does the car have A/C or not? With A/C, the resistor is mounted in the heater box under the hood. Without A/C, the resistor is likely part of the fan switch in the dash.
  5. my71bmf
    317
    May 26, 2008
    Tulsa, Ok
    The relay thing kinda makes sense. I'll try to find it. Been a while sense I have messed with that system. 20+ years.
    It was an A/C car, now just a heater only car. So the wiring is a/c, but looks and operates as a heater only car. (Changed heater box, and such)
    Thanks guys!
  6. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    3,020
    212
    Jul 31, 2001
    Ft. Lauderdale, FL
    Change the resistor. It's on the blower housing
  7. Twisted_Metal
    29,291
    2,257
    The resistor pack may have been removed when the A/C system was deleted.
    That’s the part which controls the speeds.
  8. Gary S
    23,812
    1,459
    If the relay is stuck, the fan will run on high speed all the time as it bypasses the resistor pack when it sticks.
  9. my71bmf
    317
    May 26, 2008
    Tulsa, Ok
    I know I didn't remove the resistor pack. Just gotta remember where I put it. Hopefully get to look into it today.
