Blown 79 Z28 Camaro Make it Better Project
Discussion in 'Project Progress' started by Bandit723, Oct 1, 2016.
  1. Jerry73Z28
    Jerry73Z28 Member
    86
    43
    Nov 1, 2017
    Greeley, CO
    Well done! Enjoy the fruits of your labors!
    Bandit723 likes this.
  2. DBS
    DBS Veteran Member
    366
    14
    Sep 24, 2014
    Belzoni MS
    I bet that was a good fealing
  3. Bandit723
    Bandit723 Veteran Member
    3,428
    563
    Oct 1, 2016
    Waupaca WI
    Well did another stab at aligning my hood. Body lines are still driving me nuts did shim the hood hinge at the fender gto i had had them so it helped.
    hubedobeedo and mrfleet12 like this.
  4. Bandit723
    3,428
    563
    Oct 1, 2016
    Waupaca WI
    Put the camaro thru its paces today so far no oil leaks one more win is having the headers recoated by jet hot and using the remflex header gaskets definitely took the heat out of the engine bay.
    hubedobeedo likes this.
  5. Bandit723
    3,428
    563
    Oct 1, 2016
    Waupaca WI
    More parts came in today. Been working on getting better air to the engine so purchased a new K&N filter it will be a tight fit into the bug catcher. Been having a bit of a debate on facebook if a small diameter air filter is more restrictive than an 11 inch diameter one.
  6. 80sz
    80sz Veteran Member
    3,734
    633
    Feb 2, 2014
    Buffalo,n.y.
    The engine masters have a good air cleaner shootout.
  7. Bandit723
    3,428
    563
    Oct 1, 2016
    Waupaca WI
    That was interesting so....velocity stacks it is.
    [email protected] likes this.
  8. 80sz
    80sz Veteran Member
    3,734
    633
    Feb 2, 2014
    Buffalo,n.y.
    I wonder how much it applies with a turbo or super charger. That would be a test I’d like to see.
  9. Bandit723
    3,428
    563
    Oct 1, 2016
    Waupaca WI
    Thats a good question. I know guy's that use them on their blowers and swear by them.
  10. Bandit723
    3,428
    563
    Oct 1, 2016
    Waupaca WI
    More tinkering today. I did mock up the new K&N air filter E-3340 with the bug catcher just fits. Also almost bought a Velocity stack from hardin marine. The pro's and con's of running a street engine and the looks will keep me running a filtered scoop.
