Blown 79 Z28 Camaro Make it Better Project
Discussion in 'Project Progress' started by Bandit723, Oct 1, 2016.
  1. Bandit723
    Bandit723 Veteran Member
    3,823
    740
    Oct 1, 2016
    Waupaca WI
    yeah it is something to keep you busy.
  2. Bandit723
    3,823
    740
    Oct 1, 2016
    Waupaca WI
    Did more digging into my engine woes. re-ran the leak down test and did a compression check. I backed off the rockers to ensure the valves were fully closed and did not hear any leaking from the carb or exhaust what did leak was the rings i could feel the air coming up from the drain holes in the heads.
    I am a bit confused as to the compression readings especially #8 cylinder had 180 psi reading but by looking at the plug you would never have guessed it would be that high. maybe the rings rotated or the cylinder is just that oil soaked? don't know.
    For now i will run the car as is.
    Compression readings i did not do #5 and #7 is a pita to get at those.
  3. G72Zed
    G72Zed Veteran Member
    3,496
    1,911
    Sep 8, 2015
    What was the leakdown numbers in #8 and 2 compared to the others.
    Deck height and chamber cc stack up tolerances can swing the cranking compression tests, bad second ring with excessive oil migration and carbon buildup in a chamber also raises the cranking compression, but suffers worse leakdown numbers.
  4. Bandit723
    3,823
    740
    Oct 1, 2016
    Waupaca WI
    did not use a proper leak down tester so i don't know main thing i was looking for was what was leaking and it is the rings. I know for a fact there is excessive oil in the cylinder as well as some buildup so i am sure that accounts for #8 being high. outside of this the engine runs good just uses a lot of oil. guess i can live with it for the summer just will have to clean plugs often.
  5. G72Zed
    3,496
    1,911
    Sep 8, 2015
    I hear ya. You could use a hotter plug and tighten the gap a bit in those cylinders to see if that would help.
    Just thinking if you have you ever consider going to a dual carb'd setup ? I've heard that a single carb blower application sometimes has fuel distribution issues with port to port variations.
  6. Bandit723
    3,823
    740
    Oct 1, 2016
    Waupaca WI
    well after my number of accidents with falling i did get the Camaro out today. Sucked missing IOLA but there is always next year.
  7. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,869
    180
    Aug 18, 2003
    On Wisconsin!
    Wow... we were wondering what happened to you, Mike. Good to see you are moving around again
    Iola was packed all three days
  8. Bandit723
    3,823
    740
    Oct 1, 2016
    Waupaca WI
    Thanks Harry. Hope you all had a good time!
  9. green 1977
    3,869
    180
    Aug 18, 2003
    On Wisconsin!
    as always we did... thursday crowd looked like the usual friday crowd.... busy... and friday crowd was like the saturday crowd. we got trapped on 161 on our way in on friday... was an accident by 49 that dead stopped us for 45 minutes
