Body bushings metal vs polyurethane?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by JOEY72camaro, Apr 27, 2020.
  1. Rustles
    Rustles New Member
    20
    15
    Sep 24, 2018
    I'll add my shout out for Keith's aluminum set.. poly does need the silicone grease and all of my silicone bushings have grease fittings. I think the theory here is that something that's solid can't move and therefore can't squeak so for the body do solid for movable do poly if you want precision - rubber if NVH is an issue.. I've followed Keith's (and Pozzi's) recommendations for my '70 and I think it's as close as you can get to a "budget" Pro Touring..
  2. jksvet
    jksvet Veteran Member
    244
    Dec 28, 2012
    Missouri
    Exactly what he said. I put in the metal ones because I also installed subframe connectors. I didn't like the subframe connectors because it created a much firmer ride than I wanted. Got rid of them and wish I would have put in the poly now.
  3. Rayden2009
    Rayden2009 Veteran Member Gold Member
    168
    29
    May 12, 2016
    Calgary AB
    I went from 40 year old rubber to poly to solid in about a years time. Solids do transfer a bit more road noise, but nothing to detour most drivers of these types of cars. The best overall feel probably was poly, but I ditched them when I got my sfc’s on the advise off this forum. I’ll never look back.
  4. badazz81z28
    19,656
    1,157
    Alabama
    If you hear anything but an exhaust, invest in the engine upgrade.
    flht99b likes this.
  5. badazz81z28
    19,656
    1,157
    Alabama
    SFCs don't create a firm ride...Your suspension is doing that.
    Rene Melten likes this.
  6. Rayden2009
    168
    29
    May 12, 2016
    Calgary AB
    Agreed!
  7. procharged81
    procharged81 Member
    57
    11
    Nov 16, 2011
    NE PA
    I used poly 15 years ago when I replaced my bent subframe, no issues with them, no squeaking.
    When I started my restore a few years back, I was going to replace with poly again. 2 different fab shops told me to go solid and never look back. Both said the same thing...”Why tie the front and rear of the car together with connectors, then allow the body to flex on the frame?”
    Some more road noise?? Who knows, can’t hear much over the exhaust and motor anyhow.
  8. Rayden2009
    168
    29
    May 12, 2016
    Calgary AB
    I think I may have used the wrong term. When I said road noise, I meant a little more “road feel”. Just a bit less isolation between the cabin and the rest of the car, so in turn, the road. Kind of the same feeling going from rubber/poly to solid bushings on control arms. A little more “in tune” with the connection to the road.
  9. badazz81z28
    19,656
    1,157
    Alabama
    Poly or rubber would make more sense if the rear frame rails weren't already welded to the body. You need solid with SFCs because of that. You can't have rigid frame to body in the back and squishy in the front. You just end up cracking the welds or elongating the bolt holes. Better to make it all one solid structure.
  10. raimond
    raimond New Member
    24
    Jan 16, 2020
    I don't like poly bushings because they have a tendency to get hard and squeak.
