Bodywork question regarding skim coating bondo.
Discussion in 'Body Restoration' started by Zedzag, Dec 1, 2008.
  1. Zedzag
    Zedzag Veteran Member
    528
    Jan 27, 2002
    Vancouver,B.C.,Canada
    I did some welding on my rear valance to replace a rusty area. I used zinc-chromate weld-through primer on the backside of the patch panel and on all the welds after. I would like to use a bit of skim coat finish bondo to smooth out one area. Can I skim coat right over the weld-through primer or does the area have to be bare metal? What's the rule of thumb for bondos and skim coats after body work?
  2. krabben1
    8,243
    71
    May 16, 2007
    ( . Y . )Delco
    Im not a pro,but I do know you should not put filler over weld thru primer.Bare metal,or epoxy primer is the way.
  3. wookie
    wookie Veteran Member Lifetime Gold Member
    3,037
    Jul 12, 2006
    Daytona Florida
    I'M not a fan of applying things over weld-through.....But you may be able to. I wouldn't though but that's just me..
  4. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    You can't, it's not made to be overcoated. You'll have very poor adhesion. Sand to clean bright metal, epoxy and skim coat.
  5. krabben1
    8,243
    71
    May 16, 2007
    ( . Y . )Delco
    Im liking that avatar also.
  6. Zedzag
    528
    Jan 27, 2002
    Thanks guys. I'll sand that weld through stuff off and epoxy prime first.
  7. wookie
    3,037
    Jul 12, 2006
    Daytona Florida
    ....From last years Christmas party.......;)
