Bolts or Studs?
Discussion in 'Engine Topic' started by earnhardtgm3, Feb 6, 2011.
  1. earnhardtgm3
    earnhardtgm3 Veteran Member
    3,734
    45
    Dec 18, 2007
    Camaro Country,GA
    Which is better to use on aluminum heads-Head bolts or Studs.I currently have a set of ARP head bolts and am wondering if I should go with Studs instead.
  2. justanother71
    justanother71 Veteran Member
    406
    Dec 7, 2006
    Schenectady NY
    unless you have high compression, or are running a big turbo or supercharger, good head bolts are JUST FINE. and much easier.
  3. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    NOS?
    Blower?
    13: 1 compression?
    If not,,,, the stock GM or ARP bolts are just fine, but you must use hardened washers on aluminum heads, they come with the ARP bolts.
  4. 5spd540
    12,396
    16
    Sep 19, 2009
    Guyton, GA
    ARP bolts will be fine unless you have a high compresssion motor
  5. earnhardtgm3
    3,734
    45
    Dec 18, 2007
    Camaro Country,GA
    10:1 is what I have on a mild 350
  6. 5spd540
    12,396
    16
    Sep 19, 2009
    Guyton, GA
    You will be good with bolts and you can save a little money
  7. Marks71BB
    11,833
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    ^^ THE most important part right there. And light oil on the threads and surface of the washers.
    I should not have to mention clean but I will.
  8. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    arp bolts or new gm bolts are fine unleess running race comp. like 13-1 or up or running blower or turbo.....i guess gm bolts are no go from posts below....... me learn something, ive seen guys do it but that dosnt mean its correct.....
  9. SKIP WHITE
    SKIP WHITE Member
    48
    Jan 4, 2010
    Kingsport TN
    You for sure need to use the special head bolt washers, but you must have the extended reach head bolts. The stock GM head bolts will not have sufficiant thread to secure the heads if you add the washers, but alum. heads need these washers. GM head bolts have exactly enough thread length, and none to spare for the use of these thick washers. These special washers are approx. 95-125 thick. Use head studs, and worry not about it.
  10. Marks71BB
    11,833
    Aug 25, 2002
    Yeah, If I was to drop the coin on aluminum heads then the studs would be a given. That's just me though.
