Bondora’s 71 Camaro Build
Discussion in 'Project Progress' started by bondora68, Aug 21, 2020.
  1. bondora68
    bondora68 Veteran Member
    399
    121
    Dec 14, 2014
    Mobile, AL
    Finished off the headliner by pulling the sides tighter and using the heat gun to smooth out wrinkles.
    BillyDean7173 likes this.
  2. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    My gas petal is a drive by wire unit from a C5 Corvette and sits outward a little bit more, but that duct that you are referring to does come close. It directed it upwards and over the steering column. I took some pics but it is crowded in there..
    Near the pedal, the larger duct is the driver's vent and it routes upward and over the steering column. The smaller duct sitting under the gas pedal is the lap vent duct which will run over the driver's lap vent and will no longer be down there in the way...
    tempImageUwFTbl.png tempImage4s6Ng6.png tempImagedq6OZ6.png tempImageMx3QAD.png tempImage979T6S.png tempImagenHMgzs.png
    75Maro likes this.
  3. dcozzi
    dcozzi Veteran Member
    4,173
    1,164
    May 1, 2002
    Phoenix, AZ
    Your headliner came out great. Mine still has wrinkles that I could not get out from being in its box for 15 years. I thought about trying a steamer but the heat gun may shrink it a little and help the process along.
  4. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    Yes, I had pretty good luck with the heat gun on medium setting.
  5. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    Put the restored and painted dash back in.. Used a chrome pen to put the lines on the dash..I dug out the old door panels that were nearly trashed and restored the lower panels by repairing cracks and cleaning and repainting
    tempImageuQYnUg.png tempImageQDYspn.png tempImageuALniJ.png tempImageT0mXJb.png tempImage7rv1XB.png tempImagePHHMKR.png tempImage4fYa10.png tempImageT9vxPj.png tempImagel8q5jT.png tempImagebEByqQ.png
    75Maro likes this.
  6. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    I started the preliminary wiring on my New Vintage USA gauge cluster by labeling everything on the bench and extending grounds and 12v leads.I purchased a Milwaukee cordless battery powered soldering iron that I absolutely love! It heats up in less than 20 seconds and works great.
    My console is finally finished as well.
    tempImagegXqRl3.png tempImageYr4sfo.png tempImagem9HUDH.png tempImageCP0Kan.png
    75Maro likes this.
  7. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    Gauges installed and working.
    not happy with the overall fit of the dash pad..
    tempImageO7yddy.png tempImageJJvc7z.png tempImageSpLsz0.png tempImage8in7DY.png
  8. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    I made a cup holder out of some ABS plastic using a heat gun. It fits in the console and is removable
    398FF13E-5B8C-45EF-A2FB-99E9DE914FA6.jpeg 923AE248-2BF6-41EE-B357-4333529FD314.jpeg 0D827610-ED46-4726-8D48-FC9B8F046ED9.jpeg 32AB0CB4-F771-4947-B3A9-0AA584B4201B.jpeg E5D53F50-CA4B-44AD-AA8C-8B2B1EC135B6.jpeg C1937B04-D411-4BAF-AA8A-6B35C89E6BD1.jpeg EDEF0CF6-290A-40A2-91D1-A9046DA83230.jpeg 7BF5B30A-B27A-4664-90F5-BD13D5951006.jpeg
    ..and the console lid still shuts.
  9. 69venture
    69venture Member
    31
    Nov 11, 2015
    Greenville SC
    Hey, I am is the same stages and am considering the NVU gauges as well. Planning on buying a repop dash (researching the NPD dash) and a repop bezel. You stated "not happy with the overall fit of the dash pad". Was it the fit of the restored dash itself you were not happy with or the bezel and gauges?
  10. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    I think the dash pad I have is actually a repop and not very good (came with the car in the trunk). I’m having some issues lining things up at the bottom. The gauges look awesome but could use some improvement where it meets the bezel. They are not flush together and there is a 1/2 “ gap between them. Not horrible but I wish they had put more engineering into this setup. The gauges are gorgeous however!
