Bondora’s 71 Camaro Build
Discussion in 'Project Progress' started by bondora68, Aug 21, 2020.
  1. bondora68
    bondora68 Veteran Member
    399
    121
    Dec 14, 2014
    Mobile, AL
    If you haven't noticed I like to jump around on the things that I work on...To keep from burning out and getting tired of the project. Today I began to address the last of the rust repair. The rear window channel had a small hole and as soon as I started sanding it and the putty fell away, it became a larger repair. After patching this I went to clean up the rest of the window channel and of course I found another area full of putty and patched that as well. Tomorrow I will be tackling the final wheel well quarter panel area..
    tempImager1GtU5.png tempImageSqKZUC.png tempImageokVuo1.png tempImage9LioH7.png tempImagevuwR7Z.png tempImage1yoMNE.png tempImageE5AqqX.png tempImageINEJOL.png tempImagerCnFcL.png tempImageaUZ17D.png tempImageX4rMve.png tempImageLQwMe4.png
    [email protected] likes this.
  2. brooksman9
    brooksman9 Veteran Member
    6,298
    307
    Jun 10, 2007
    Olive Branch, MS
    Looking good man.
    bondora68 likes this.
  3. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    Sanded and painted the headliner trim and the pillar post trim.. 649682CD-2E3C-4409-8CAB-2258804F7DAC.jpeg BBDF8CDC-0BFF-4F10-806B-5E7FF4FAC2EC.jpeg 1322B30F-9DD2-422B-ABA2-E10443A78C59.jpeg
  4. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,645
    1,060
    Mar 27, 2016
    NY
    Looks good, what are you using for the front and rear, thee stuff I found as a replacement was not as good as the original stuff that I took off, the old stuff was even more pliable then the new, HAA HA
  5. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    I'm using the original front and rear windlace type pieces.
  6. Oldskool62
    Oldskool62 Veteran Member
    164
    60
    Sep 29, 2017
    Looking good.
  7. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    So I ruined the headliner today. I had taped the wires for the dome light between the 2 screws for the dome light housing. I went to cut the hole and did not realize that the tape had come loose and the wiring had shifted forward so I cut the hole too far forward. Now I have to redo the headliner with a new one. I was very mad and said some words that were vile.
    Another issue..After wiring up the wire harness for the JVC Stereo I bought I find out that it does not have bluetooth even though the online description said it did. So I cut out the old harness and spent an hour soldering in the new one.
    On a positive note, I was finally able to get the lower dash leveled out and look decent after a lot of work lying down and reaching under the dash.
  8. dave@ztech
    4,645
    1,060
    Mar 27, 2016
    NY
    Well that sucks, on the headliner, however, if your install looked like mine, a second go at it, would not be the worst thing , HAA HA
    bondora68 and 75Maro like this.
  9. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    Found out my rear seat bottoms are rusted beyond repair..
  10. bondora68
    399
    121
    Dec 14, 2014
    Mobile, AL
    I lucked out and found a guy less than 10 miles away who had a complete backseat set in much better condition than mine for only $75.
