Bondora’s 71 Camaro Build
bondora68
621
Mobile, AL
She is patiently waiting until spring break for her new transmission...
bondora68
621
Mobile, AL
Operation Trans! Wait, what?
Total pain in the butt trying to do this without a lift. I used my jack to lower the trans after removing the crossmember, which would only come out when I loosened the exhaust from the engine. I had to lift the car up even higher to slide out the trans from underneath... Putting in the new one will be a real challenge I'm sure...
Fbird
6,450
atlanta, ga
looks like a th350 came out...whats going in?. There is a method to floor work!!! I posted a tip-trick on holding the converter in place (forgot where I actually stole the pic) but the short story is,,,SLIDE the tranny under car on pc of cardboard (yes you need to pick up the rear of tranny to get bell housing under frame rail)...THEN once under the car put tranny on jack. Otherwise you need the car like 5 ft off the ground...lol
