• The Forum will be unavailable on March 27, 2023 from 8:AM to 12:00 PM EST for maintenance.
Borgeson quick turn steering box
VSTOL
VSTOL
Sep 21, 2019
81
Stafford VA
I just installed the Borgeson quick turn steering box and OMG what a difference. With the Hotchkiss sway bar, new rag joint and Flaming River Steering column, my 72 Camaro just became a blast to take on the back roads. Based on my last two c2 and c3 corvette builds with rack and pinions from a C4 corvette, this falls right up there with them. I highly recommend it
CopperTop
300
Mass
Do you have a link to this box? I am currently in the market for one.
ULTM8Z
10,880
Los Angeles
You should do the u-joint steering shaft conversion too.
Yeah the combination of their box and steering shaft conversion is phenomenal.
biker
5,821
Ya, I think the rag joint would be just as good as a u-joint as far as linear feel goes. At least in the short term before heat and wear gets to it. Rag joint is cheap, pop a new one in e ery 5 or six years. I like the u-joint too, but took extra time to clearance the frame so the vibtation isolating joint would fit.
Burnttoastburgos
216
Colorado
so, question....whats the performance between what the o.p installed and a properly running set up from a 1979 Z28? And by properly running set up, i mean, NO SLOP in steering components at all....I ask as I see this come up quite a bit and, I myself, thought the oem steering box/steering components in good as new condition from a 79 steers awesome...you mean It can get better?....thank you
biker
5,821
After a few days of driving with the new box in my 81, it is definitely better than the stock box. Much quicker initial turn-in, very nice "feel" to the steering. Not quite apples to apples now though. I have much more caster with the adjustable upper control arms and a type II steering pump.
