Bottom end bog
Discussion in 'Troubleshooting & Diagnosis' started by Bryce Maese, Oct 5, 2021.
  1. Bryce Maese
    Bryce Maese New Member
    19
    Apr 2, 2021
    Hey everybody,
    I just finished rebuilding my stock 350 with a new intake, Holley 680 brawler, msd distributor and digital 6al, it runs great and is scary fast but at the very bottom end on low speed acceleration at almost exactly 1000 rpm the car bogs and then breaks out of it by 1300-1400 rpm, I have tried adjusting the primary fuel pump arm, float level, timing, vacuum advance, any ideas
    Thanks
  2. carhead22000
    carhead22000 oldblue
    763
    348
    Sep 5, 2011
    canada
    does that primary pump shot have a diaphragm. Check it.start there.
  3. Bryce Maese
    19
    Apr 2, 2021
    Well I haven’t looked at it but the carburetor is brand new so could this still be a problem
  4. carhead22000
    763
    348
    Sep 5, 2011
    canada
    did you get a backfire at any time at all.if so its a place to start.try a carb spacer.i,m sure more guys with more experience will chime in.
  5. MChamp
    MChamp Veteran Member
    410
    112
    Jun 6, 2021
    north carolina
    Power valve not sized correctly. At the proper vacuum I should say. There's a guy on here that's a freekin carb guru. I'll look
  6. Bryce Maese
    19
    Apr 2, 2021
    Any luck finding said carb guru
  7. MChamp
    410
    112
    Jun 6, 2021
    north carolina
    Not yet, I've looked through all my posts but can't find the thread. I'll keep digging around but I still lean to a lighter power valve.
  8. Bryce Maese
    19
    Apr 2, 2021
    Alright thanks
  9. Bryce Maese
    19
    Apr 2, 2021
    if those are the current specs what would you think as a replacement
  10. Lowend
    16,544
    1,302
    Mar 25, 1999
    San Jose, CA, USA
    Let's start off with the most common one: Have you checked for a vacuum leak?
