Brad Penn/Penn Grade "green oil" turning black
Discussion in 'Engine Topic' started by Lynd McCormick, Nov 6, 2019.
  1. Lynd McCormick
    Lynd McCormick Member
    87
    Oct 6, 2017
    Finleyville, PA
    80z..... thanks, then I’m less concerned.
    thanks all for the replies!
  2. Vettenick
    Vettenick Vettenick
    350
    67
    Jul 17, 2019
    Since it appears that some of us have different ideas on what's normal and what isn't....if you're really concerned, send a sample out for analysis. It's not expensive, and it will give you peace of mind. You might actually find out things that you didn't know. If you do that, please let us know what you found out. Good luck!
  3. rocket dawg
    rocket dawg Veteran Member
    484
    60
    May 5, 2015
    Grand Rapids Mi
    10 w40 brad penn and mine was darker than other oils, not black but fairly dark for the amount of miles it was run. I switched to Valvoline for older cars and it seems to hold its color much better.
  4. 80sz
    80sz Veteran Member
    3,928
    748
    Feb 2, 2014
    Buffalo,n.y.
    Maybe brad penn traps carbon way better than other oils? Honestly after I pulled dip stick after changing oil I said same thing, wow that went black fast. My new motor it hasent changed as quick, it’s not as rich running as previous set up. Still see green in it with 200 miles
  5. 76z28
    76z28 Veteran Member
    2,384
    180
    Jun 29, 2009
    bakersfield
    I noticed it when I used brad penn too. I use Mobil 1 now and since fuel injection my oil stays cleaner much longer... Gotta love a fat carb.
