With the engine off, parking brake not engaged, key in "run" the brake warning light comes on.
Remove the wire from the combination valve switch terminal, brake light goes off
Push the parking brake pedal and the light comes on
Release the brake and the light goes off
From a Twisted Metal posting, when one side of the switch piston has more pressure then the other, it moves into contact with the pin at the end of the switch terminal, closing the circuit which lights the warning light
What do I need to do?
