Brake fluid exchange advice
Discussion in 'Troubleshooting & Diagnosis' started by severum17, Mar 5, 2017.
  1. severum17
    severum17 New Member
    29
    Sep 5, 2001
    South of Dallas TX
    So, I am the original owner of a 77 Z. Still has the original brake fluid. Yeah, I know, but it still stops and functions fine. This has been bothering me and I know it needs to be flushed but I dont want to open a can of worms. If I flush it with fresh fluid am I looking for issues with seals and brake cylinders? What DOT should I use. It stops now and I dont want to end up replacing the calipers and cylinders. Thoughts?
    Thanks MikeM
  2. Gary S
    23,665
    1,391
    Use the recommended fluid. Don't change to anything else. New fluid shouldn't cause any issues with seals or cylinders. It should extend the life of them as it won't have debris in it like the old fluid might have already.
  3. Bandit723
    Bandit723 Veteran Member
    3,425
    562
    Oct 1, 2016
    Waupaca WI
    More that likely you are using DOT 3 fluid but i would test it first. Even with a flush and put in the wrong fluid, you could cause issues if you do not get it all out.
    DOT 3, 4, and 5.1 can be mixed if necessary, according to the instructions on the cans. The temperature range is higher as it progresses from DOT 3 to 4 to 5.1
    DOT 5 and DOT 5.1 are not the same.
    DOT 5 is a silicone based fluid, and DOT 3, 4, and 5.1 are glycol? based.
    don't guess.... this is how to check:-
    Essentially, there are two types. The first one is regular auto brake fluid. The second type is Silicone-based brake fluid.
    You can not mix the two types of fluid (well, you can, but you will end up with a jelly-like mess).
    You need to find out which you have already in the system. Here's how:-
    1. Get a dropper (an eye or ear-dropper) and withdraw some fluid from the master cylinder.
    2. Put it into a glass jar and then add some clean water to the fluid.
    3. Now put the lid on the jar and shake it well.
    4. Let it stand for a few minutes.
    5. If the water and the fluid have mixed thoroughly and can not be separately identified, then you have regular auto brake fluid.
    6. However, if the water and the fluid have not mixed, or have formed blobs or layers, then the fluid is Silicone.
    That's all there is to it. Lots of people think that you can recognise which is which by looking at the colour of the fluid, or by its odor. Don't risk it. Use the test outlined above. It's already been said that DOT 5 is not always purple, or that it can change color after time to a yellow that looks like DOT 3.
  4. BonzoHansen
    20,558
    1,705
    Jun 1, 2005
    Scott from Hamilton, NJ
    Empty the master using a siphon or even a turkey baster. Fill with clean dot3. I wouldn't mind wasting fluid, i'd gravity bleed each wheel until the master is low, close the bleeder, refill, next wheel. Rr,lr,rf,lf. You can always pedal bleed each wheel afterwards if you want.
    If you run into any issues with seals then you were gonna have issues anyway. I cant imagine 40 year old wheel cylinders working well or even lasting that long. You are on borrowed time imo.
  5. severum17
    29
    Sep 5, 2001
    South of Dallas TX
    silo.jpg [​IMG]
    Believe it or not, they still work fine and I know what fluid is in it. Its factory. I bought it new and its never been changed. I figure now is the time. Will I get dinged for not having OE brake fluid? Its time to do some basic maintenance on this original car.
  6. BonzoHansen
    20,558
    1,705
    Jun 1, 2005
    Dinged? You mean for judging? No. brake fluid is not date coded lol
  7. severum17
    29
    Sep 5, 2001
    South of Dallas TX
    Shoulda been an LOL for my statement. Not worried about date coding.
  8. Bandit723
    3,425
    562
    Oct 1, 2016
    Waupaca WI
    Totally missed the original brake fluid part. If it was not and did not know you do now have a way to test it...
  9. COPO
    20,069
    1,986
    I use Dot 3 in my 70 Z28 and I'm sure it was used in 77 unless they upped to Dot 4.
  10. Gary S
    23,665
    1,391
    Your owner's manual should tell you what fluids to use on the car.
