Brake line adapter for Wilwood proportioning valve
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by AJ81Z28, Apr 18, 2018.
  1. AJ81Z28
    AJ81Z28 Member
    49
    Mar 21, 2017
    Each new combination valve I would get after warrantying it out would eventually leak in six months. I decided to put in a Wilwood proportioning valve and change the brake lines out from the master cylinder. Anyways, I have not been able to find a brake line adapter to go from the rear brake line to the Wilwood.
    The rear brake line is 9/16 - 18 flare 1/4 inch tube. The Wilwood has a 1/8 NPT. It came with an adapter that was too small on the flare side. So my friend chopped up the combination valve and welded the adapter to the combo valve piece. It worked out pretty well but he kind of messed up the threads. So it started leaking after a few days. So do I have to go to a junkyard and repeat the cutting welding thing to make another adapter? Or has someone done this before and found an adapter?
    My other option would be to yank out the brake line and put a smaller fitting on it after cutting off the 9/16.
  2. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    There is one place I found the 9/16-3/8 flare adapters but hard to find. Using a 1/8 NPT to 3/8 could get that to work -or put a 3/8 flare nut on the line and re double flare it.
    There are prop valves with a 3/8 flare built on them.
  3. Quick stick
    Quick stick New Member
    Apr 18, 2017
    Edmonton Alberta Canada
    I recently upgraded my front brakes on my 1980 Z28 with Wilwood Dynalite brake kit. I kept the rear drum brakes as I have built the car for drag racing. The problem is adapting the male 9/16 X 1/4 X 18 hard line fitting to the female 3/8 x3/16 x24 size used on the residual valve and the proportioning valve. I contacted Wilwood with no luck resolving this issue. The hunt for a fitting finally took me to BrakeConnect hardware and tools. They had the fitting I needed, they call it a thread changer part number BQ261 $ 3.66 US. BrakeConnect has an amazing selection of fittings and adapters. I've seen some pretty scetchy ways to overcome this problem by using multiple fitting that don't always belong together! This is the safest way to make the connection.
  4. badazz81z28
    20,312
    1,325
    Alabama
    I actually just swapped the entire steel line from 1/4" to 3/16".
  5. Zee
    Zee Veteran Member
    1,088
    8
    Feb 6, 2000
    Montgomery IL
  6. dcozzi
    dcozzi Veteran Member
    4,053
    1,055
    May 1, 2002
    Phoenix, AZ
    I found the adapter I needed on the Dorman rack at O'Reilys or Auto Zone (cannot remember which). Cost about $8 for 2 of them.
    Zee likes this.
  7. Zee
    Zee Veteran Member
    1,088
    8
    Feb 6, 2000
    Montgomery IL
    Share the PN so those in the future don't have to spend $90 to have a new line made like I did :whine:
  8. dcozzi
    4,053
    1,055
    May 1, 2002
    Phoenix, AZ
    I wish I could. I threw away the packaging at least year ago.
    I think I used this valve with the adapters off the Dorman rack to resize the inlet/outlet.
    https://www.summitracing.com/parts/wil-260-10922
    If you do not have their part numbers already, it is difficult to order anything directly from Wilwood. I had to buy separate adapters to plumb the line into their master cylinder as well. The kit did not have the right size included.
    Zee likes this.
