cannon11495
So after 7 years of my 77 Camaro being in storage I finally got everything ready to do a test drive. On my test drive I realized I have almost zero brake pedal, it barely catches right at the end. So I take it home and start to try to bleed the brakes, long story short I couldn't get brake fluid out of any of the bleeder screws. I even took the bleeder screws all the way out on Passenger front a back (drivers side back the bleeder screw was broke off so I was unable to get a wrench on it) my drivers side front I cracked loose and got a dribble of brake fluid out of it. Does this seem like a Master Cylinder issue, or maybe the proportioning valve? The brake fluid looked really bad probably never been changed. My other question is I think since i am messing with the brakes I am just going to do a full rebuild of all my brakes, all my rotors and components are pretty damn rusty, since I am going to spend the money to buy all brand new brake parts is it worth it to convert the rears to disc brakes while I have everything ripped apart? Also what kits have you guys found or what brakes sets do you like to use? Thank you all in advance for your help! Sorry this was a long one!
