smallblockchev
Checked lines and banjo bolts all tight and no leaks.
Made that mistake once, 2 days of trying to get the brakes to bleed. Sometimes I do things the hard way.ok one more question and not to imply anything, but we have done it before. The bleeder is facing up not down correct?
Gravity bleed works well, then follow up with traditional bleed. If it doesn't pump up and get rid of air, you may have a bad master. Even if it's new.Try a gravity bleed with a factory bleeder.
He said when he clamps off the front calipers the pedal builds pressure. That would make me think the master may be okGravity bleed works well, then follow up with traditional bleed. If it doesn't pump up and get rid of air, you may have a bad master. Even if it's new.
OK good, I missed that one. And yes, I've had calipers that don't leak fluid, but will suck air... not fun to chase down.He said when he clamps off the front calipers the pedal builds pressure. That would make me think the master may be ok
