Brembo Brakes
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by BAAVY05, Dec 2, 2015.
  1. BAAVY05
    BAAVY05 Veteran Member
    223
    Jun 24, 2006
    Richlands,N.C.
    I am wondering can you fit a set of brembo brake calipers on a 72 camaro
  2. badazz81z28
    20,569
    1,383
    Alabama
    In what regard? Wheel size is your main concern. Many brakes will fit on a sec gen with the correct kit
  3. AlbertaZ28
    AlbertaZ28 Veteran Member
    298
    8
    Aug 17, 2010
    Fort Mcmurray, Alberta
    I just bought a set of used 5th gen callipers and rotors. I will let you know in a couple months. I know you can buy everything needed for the rear from bigbrakeupgrade.com, but the front will be a custom bracket and hub. And you will need at least 17in wheels maybe 18's.
  4. AlbertaZ28
    298
    8
    Aug 17, 2010
    Ok I have my calipers and rotors. After a bit of sizing up it looks like they will mount up pretty easy front and rear. The only problem will be with the rim clearance, not the diameter but the caliper face to rotor clearance. Which depends on the rims you are running.
  5. AlbertaZ28
    298
    8
    Aug 17, 2010
    Only 2.5 years later but I have my fronts figured out. I am using 6th gen calipers and rotors with brackets from Bigbrakeupgrade.com. With the 6th gen I will not need a wheel spacer for the caliper to clear my wheels. The 5th gen callipers and rotors will also work but I will need 12mm wheel spacers.
    Zulu28 likes this.
  6. rcsf500
    rcsf500 New Member
    26
    Nov 21, 2010
    White Lake,MI.
    Any chance you could post a picture of bracket,maybe with some dimensions
  7. AlbertaZ28
    298
    8
    Aug 17, 2010
    If you go on bigbrakeupgrade.com there are pictures of the bracket. It is not my design so it wouldn't be right to share the dimensions of it.
  8. rcsf500
    rcsf500 New Member
    26
    Nov 21, 2010
    White Lake,MI.
    Fair enough,thanks
  9. Zulu28
    Zulu28 Veteran Member
    299
    26
    Dec 19, 2013
    Vancouver, BC
    Good job, nice upgrade for the money!
