Broken leaf spring
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by cam2z28, Jan 23, 2018.
  1. cam2z28
    cam2z28 New Member
    9
    Nov 12, 2013
    Shoemakersville, PA
    I went and dropped my rear axle and springs to sand and repaint. Taking the spring assembly apart the bottom spring(the little one) I dropped it and it broke in half on the passenger side. Can I just buy one spring assembly(passenger) or must it be both sides. Normally I would replace a set but money is tight right now and would like to get this thing together. Is there anyplace to buy the broken spring only? FYI it is a 5 leaf. Thanks
  2. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    Where are you located? I have a pair of Z/28 leafsprimgs in Northeast Pa.
  3. cam2z28
    cam2z28 New Member
    9
    Nov 12, 2013
    Shoemakersville, PA
    Do you know where Hamburg PA, I'm 10 min south from there. How much are you asking?
  4. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
    Check with your local spring shop (if there is one) you should be able to buy just the one leaf.
  5. cam2z28
    cam2z28 New Member
    9
    Nov 12, 2013
    Shoemakersville, PA
    Checked with a spring shop and your right APEowner, Got one for $20. Thanks
