brown tach wire
Discussion in 'Troubleshooting & Diagnosis' started by joer, Jan 20, 2021.
  1. joer
    joer Veteran Member
    245
    Sep 25, 2008
    East Brunswick, New Jersey
    Does anybody have a pic of where the brown tach wire comes out of the fire wall. need to hook up to msd box. can't seem to find it.
  2. Gary S
    24,071
    1,589
    A previous thread here on the board showed us that they didn't punch that hole in the same place on all cars. My tach wire comes through the dash over to the driver's side of the brake booster. The wire then drapes over the booster and to the center of the car to the coil. My car is a 1970.
  3. joer
    joer Veteran Member
    245
    Sep 25, 2008
    Thanks, mine is a 79. it would have snapped into the HEI distributor. It's been a while but i think the wire is much fatter with an end on it.
  4. DougD
    DougD Veteran Member
    407
    139
    Dec 2, 2014
    Bradenton, FL
    Anywhere it might be, it comes out of a nipple as shown in the picture above. It's 18GA if memory serves.
  5. joer
    joer Veteran Member
    245
    Sep 25, 2008
    Ok, I'll check it. Thanks again.
  6. joer
    joer Veteran Member
    245
    Sep 25, 2008
    Would this be the tach wire. how would I hook it to my MSD box. No more after market tachs.
  7. DougD
    407
    139
    Dec 2, 2014
    Bradenton, FL
    I'm too blind to see that image :( Needs to be MUCH larger. Others can answer, I'm sure.
  8. joer
    joer Veteran Member
    245
    Sep 25, 2008
    You seem to be the only one who wanted to help. will a larger pic help.Also the pic on my valve cover. Would it be a filter from the tach?
  9. DougD
    407
    139
    Dec 2, 2014
    Bradenton, FL
    Yes, and yes. That is the tach wire and that is the filter. For the MSD box, I can't answer, but I'd think it's available online at their site.
    2ndGenCrazy likes this.
  10. joer
    joer Veteran Member
    245
    Sep 25, 2008
    Great, Thanks again.
