Me and my dad recently got a project 1979 z28 it’s an automatic I’m asking for any tips/advise to increase the power of the stock motor or any performance upgrades that will make a difference to the feel of the muted motor I’ve heard that changing the heads will make more power but at 82,000 miles I don’t know if it’s even worth it. Thank you.
I myself like long tubes but for your Camaro it's all dependent on if your Camaro is lowered then you might end up with clearance issues running long tubes
I don’t plan on lowering it right now maybe later on but I’m going to stick with the stock ride hight right now so I’ll look into going with long tubes thanks
Intake .headers true dual exhaust .and tune your carb for it is a start.You can even make you hood scoop functional as well.
I am a big fan of “free” horsepower, the things that don’t necessarily cause your engine to work harder but reduce parasitic loss. Electric fans help substantially over the old stamped steel fans. I will have to find the write up again but the stamped steel fans were like 25-30 horsepower. Flex-lite mechanical fans were in the 10 horse range. Also lower gears is the best seat of the pants performance upgrade price wise. Just my .02
There was an Hot Rod magazine article that shows you how to do so .Just Google "How to make a 1979 Z-28 hood scoop functional .And then go to the Nasty Z-28 article "Functional hood scoop " It has a lot of information on how to do .With suggestions from other members as well. I have a 1979 Z-28 also and when I started modifying my car ..I did this modification to it.And if you have any further questions I as well as others can help you .Good luck .
The factory catalytic converter on those cars was junk when they were new. Assuming that's still in place, replacing that with a modern cat is your single biggest bang for the buck. From there, I'm putting an advance kit in the factory HEI.
