Budget horsepower?
Discussion in 'High Performance Modifications' started by Abz28_79, May 29, 2020.
  1. 1980RS
    1980RS Veteran Member
    4,769
    1,413
    Jun 17, 2006
    MN
    It most certainly would. You will need to get a different distributor for the engine as the TBI one will not work with it.
    joeparamonkey likes this.
  2. joeparamonkey
    joeparamonkey Member
    79
    May 17, 2012
    San Antonio, TX
    Thanks. I looked at Summit Racing for the dizzy, I really didn't know which one would fit the bill. Does it have to be computer controlled advance?
  3. Fbird
    5,116
    1,226
    Feb 12, 2011
    atlanta, ga
    oh... i was thinking F-body engine.....those were sfi ...the trucks were still TBI so YES on the swap pieces.
    No the dizzy needs to be mechanical NOT computer controlled as you will no longer have/need a computer.
  4. joeparamonkey
    79
    May 17, 2012
    San Antonio, TX
    Awesome, thanks
  5. 1980RS
    4,769
    1,413
    Jun 17, 2006
    MN
    If you are running a non-computer engine with a carburetor than you can use anything with a advance curve. Basically the EFI and SFI engines are locked distributors and use the curve with the programming that's in the PCM, nothing more.
