Build Sheet Location???
Discussion in '1978 - 1981 Specific' started by dillon14, Sep 21, 2015.
  1. dillon14
    dillon14 New Member
    19
    Sep 30, 2012
    Thomaston, maine
    On a Norwood Ohio 1980 Z28 with bucket seats, does anyone know of the common places you might find the build sheet?
    Thanks,
    Al in Maine
  2. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    "The sheet is often located either behind the rear seat, or over the gas tank. On newer models, the build sheet might be stuffed under, or in a seat."
    http://www.nastyz28.com/buildsh.html
  3. twozs
    twozs Veteran Member
    8,817
    172
    Aug 5, 1999
    hopewell jct ny
    or in the garbage can at the plant .
  4. twozs
    8,817
    172
    Aug 5, 1999
    hopewell jct ny
    Lansing ??? that's Oldsmobile teritory...
  5. TxGold
    TxGold Member
    37
    Jul 13, 2014
    Houston
    I found mine behind the rear seat back.
  6. dillon14
    dillon14 New Member
    19
    Sep 30, 2012
    Thomaston, maine
    Sorry, it is actually the Norwood Ohio assembly plant.
  7. dillon14
    dillon14 New Member
    19
    Sep 30, 2012
    Thomaston, maine
    Found it behind the rear seat back. It proves that the car was a real LM-1, 4-speed with factory A/C. Wicked cool to find it.
    Thanks,
    Al in Maine
  8. badazz81z28
    20,535
    1,379
    Alabama
    My Norwood 78 had one behind the seat and on top of the tank. My 70, LA car, all I could find was on top of the tank and there wasn't much left
  9. 1980camaroguy
    1980camaroguy Veteran Member
    228
    Dec 8, 2008
    Carleton, Mich.
    Build sheet under rear seat
    Al,
    My 1980 camaro build sheet was undernieth the rear seats.
  10. blade0817
    blade0817 New Member
    Jul 31, 2015
    Minneapolis MN
    Check under the driver's seat as well, that's where I found mine. 1981 Z28 manufactured in April 81 in LA.
