Build sheet
Discussion in '1978 - 1981 Specific' started by Scott Sievers, Apr 10, 2020.
  1. Scott Sievers
    Scott Sievers Veteran Member
    239
    100
    May 22, 2018
    SE Iowa
    Anyone got a link to decoding the build sheet? I decided to see if mine was there today.. it was! It says M21 Trans though... I didn't realize they were still using muncies in 1980?? Anyhow, thanks!!!!
    I tried to upload the scan I took of it as a PDF but keep getting the error that the extension is not allowed? .pdf isnt allowed?
  2. Gary S
    23,087
    1,088
    M21 on the build sheet is the RPO for a close ratio 4 speed tranny that you could order. It just so happens that many years earlier, GM used M21 as a model number for a close ratio Muncie. These do not mean the same thing.
    In the early 70s, RPO M21 on the build sheet got you a M21 Muncie.
    By 1980, RPO M21 got you a Borg Warner 4 speed tranny.
  3. 70lt1z28
    3,691
    751
    Oct 3, 1999
    Beavercreek, Ohio, USA
    And to make it even more confusing, in the early 70's M20 could mean either a Muncie OR a Saginaw.
  4. Scott Sievers
    239
    100
    May 22, 2018
    SE Iowa
    Awesome... and found what I think is the page for the codes on the build sheet..
  5. Glava
    Glava Veteran Member Lifetime Gold Member
    409
    26
    Mar 23, 1999
    Central NY
    Yup, my 79 has RPO M21 on the build sheet -which confused me too when I found the build sheet years ago.
    The Borg Warner is a T-10 aluminum case, which is a decent tranny right?
  6. Scott Sievers
    239
    100
    May 22, 2018
    SE Iowa
    Not entirely sure... Super t10 was upgraded and supposedly pretty strong... My experience from back in the day was to Ditch the t10 and scrounge the salvage yards and find a M21 or better an M22. Although I ran several t10's behind big blocks, as long as you didn't slide your foot off the clutch at 5000 rpm they did okay.. if you did slide your foot off the pedal at 5000 rpm it snapped the output shaft off right where the splines started... Not.... that I ever did that....
  7. Gary S
    23,087
    1,088
    The T10 is equal to the Muncie in strength. GM quit making Muncies in 1973 and started buying T10s from Borg Warner. These T10s from 1973-79 were quite close ratio and have aluminum cases. Starting in 1980, EPA standards called for better fuel economy so Chevy dropped the 3.73 rear gears in favor of 3.08 gears to get better mileage. The change required a wider ratio T10. Widening the ratios in a manual tranny weakens it as the wider gears put more stress on the case. I believe you will find that these later wider ratio T10s will have cast iron cases to make them stronger.
  8. 1981 Berlinetta
    1981 Berlinetta New Member
    8
    Jul 30, 2019
    Timmins ON
    not 100% on topic but. I purchased a 1980 Z28 for parts just after Christmas, car is pretty rough. I removed the rear seats yesterday and there was the build sheet. 40 years and rear seat was never removed. Pretty cool
    PS, Saginaw 4 speed, iron case.
  9. Gary S
    23,087
    1,088
    Have you checked the casting numbers on that tranny? Some sources indicate that an 80Z28 should have originally had an iron case Borg Warner.
  10. 1981 Berlinetta
    8
    Jul 30, 2019
    Timmins ON
    I’ll check casting numbers once I pull it out of the car but using google, checking pictures and charts it’s looking like a Saginaw.
