Building trunk area for subs?
Discussion in 'Car Audio, Electronics & Security' started by RJ45, May 5, 2015.
  1. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    Whitehouse Station, NJ
    I have two 10" JL Audio 10w3v3 2 ohm subs. They will be powered by a Rockford Fosgate Punch amp, P500x1bd. The open space in trunk (after wood surround) where speakers will be pointing is 4' wide x 1 1/2' deep x 1 1/2' high. Is that enough open space? The subs will go in a dual sealed 3/4" MDF box with 1/2" birch ply boxing the trunk surround with two amps and power block mounted in that space. Rattletrap sound/heat material will cover just the floor. I have a fiber panel on the back of the rear seat. Here are a couple pics of the work in progress.
  2. 75Camaro4x4
    75Camaro4x4 Veteran Member Lifetime Gold Member
    345
    Aug 5, 2013
    Wilson, NC
    Hey! A belva box! I deal them lol, but haven't ordered one to test. Cool false wall, I haven't had the chance to build one yet, just false seats.
  3. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    Do you think the footage I gave is enough space? I'll be adding side walls and raised flat floor.
  4. 75Camaro4x4
    345
    Aug 5, 2013
    Wilson, NC
    Yes, that space is fine.
  5. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
  6. Iknow2
    Iknow2 Veteran Member
    137
    Aug 6, 2014
    Houston, Texas
    Looks Awesome!
  7. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    Thanks!
  8. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    Used Loctite PL Pro Premium Polyurethane Adhesive plus welded studs.
  9. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
  10. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    Looks good. Nice work!
    How's it sound?
