Building trunk area for subs?
Discussion in 'Car Audio, Electronics & Security' started by RJ45, May 5, 2015.
  1. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    Whitehouse Station, NJ
  2. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
  3. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    AJ, how do you like it? It seems like a real nice unit. I made a few settings. What are your settings? Do you have a subwoofer.
    SOUND SETUP:
    C.Audio - ?
    EQ10 Preset - Rock
    EQ10 Setting - ?
    DSEE - I think I set to "on"
    Loudness - On
    SW Level - ?
    SW Phase - ?
    LPF Freq - I believe "100Hz" (seemed to get better highs)
    LPF Slop - ?
    HPF Freq - ?
    HPF Slop - ?
    AUX Vol - ?
    BTA Vol - ?
  4. AJ_72
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    First I'll start by saying, I have it in my '12 Civic, not my Camaro. Obviously I have different equipment, too. I have Coustic Audio 6.5" components in my door with only the HU powering them. I also have two 10" Fosgate P3 10" subs in a ported enclosure tuned for 40Hz with a Kicker ZX1500.1 running them at 4 ohms (roughly 750 watts), so while my settings work for me, you should only use them as a starting point.
  5. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    Thanks AJ, that helped a lot. I have two Infinity Kappa 6x9's in the rear tray and 2 Infinity Kappa 6.5's in the front toe kick. They're powered with the Rockford Fosgate P600x4 and the RF P500x1BD for the subs. I'll have to mess with mine settings to find what sounds best. Thanks for the info.
  6. AJ_72
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    You're welcome.
    Let me know when you want to start playing with the listening position. First recommendation I'll make is, if you have an Android phone, or access to one (a friend's), you can download the app-remote from Google Play and you can fine tune the timing alignment in millisecond increments. It's nice. :D
