Built 8.5" 10 Bolt Rear End
Discussion in 'Swap Meet Section' started by Jon Randolph, Apr 11, 2018.
  1. Jon Randolph
    Jon Randolph Member
    85
    May 22, 2017
    Barrington, IL
    Up for sale in this ad is my 10 bolt rear end from a '79. I have over $1k in parts in this rear end and it's been pretty well thought out for how I had it set up. Only reason for selling is because I'm moving to a new house fairly soon and need a little extra cash. I had this rear end set up for 2.73 highway gearing to make for a "cheater overdrive" behind a 4 speed and shorter "pro-touring" type tires. With the axles welded to center section and 30 spline upgrade, this setup should be able to take some serious horsepower. The Strange pinion yoke is machined to accept a speed sensor so that a traction control can be utilized with a drag race style efi computer. If going behind a manual transmission, I would suggest a trans with 2.64+ 1st gear ratio. Would be great behind an automatic as well. This is a great deal for anyone who wants to buy. Price is as low as I will go and not negotiable.
    -Moser 30 spline axles. Currently has press-in studs for stock 2nd gen lug nuts but the flanges are also predrilled for screw-in 1/2" wheel studs if desired.
    -Eaton Detroit Truetrac carrier (30 spline upgrade)
    -Strange Engineering 1350 chrome moly driveshaft yoke (https://www.strangeengineering.net/product/gm-8-5-10-blt-yoke-1350-strange-chrome-moly.html/)
    -Motive Gear ring and pinion (2.73 ratio)
    -Crush sleeve eliminator kit
    -Axle tubes fully welded to center section by Rocket Racing in Waterford, WI. (https://rocketracingperformance.com/)
    -Wheel studs set up for stock style 2nd gen lug nuts and wheels
    $600
    Below is when I had it built last year (brakes not included).
    [​IMG]Untitled by Jonathon Randolph, on Flickr
  2. dave@ztech
    4,414
    981
    Mar 27, 2016
    NY
    I wish you were closer, it would cost plenty to ship to NY, I think, but I would buy it in a second!!
  3. hutchenc
    hutchenc Veteran Member
    345
    Aug 21, 2007
    Wyoming/Colorado
    Where are you located?
