@hd_cat , do you have 90° boots on both ends of your spark plug wires?Good afternoon, comment on the intake, if you'd like to improve the finish, I used acid wheel cleaner and the dollar-store stainless steel wire brushes to buff the finish, I then used a Dremel and stainless steel cupped wire brush for the tighter areas, the Victor Jr. I have cleaned up nicely with that technique. It's a little brighter than the original finish, but the brushes didn't add swirl marks or do away with the sand cast surface. Here are a couple of photos if you're interested 3045 is the most recent photo, the others are more than two years old, the car has been back together and driven a bit since October 2020.
