Calling all owners of Moog 5610 springs in front!
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ProjectCam76, Jan 9, 2016.
  1. ProjectCam76
    ProjectCam76 Veteran Member Lifetime Gold Member
    275
    Aug 10, 2015
    Birmingham, Alabama
    I need to see more pictures of the owners that have Moog 5610 springs in front! My tires rub after I installed my new tires and wheels combo. Apparently, my original stock front springs have collapsed over time.
  2. ProjectCam76
    275
    Aug 10, 2015
    Birmingham, Alabama
    Also considering Moog 5608 springs
  3. CorkyE
    11,370
    902
    This is 5610 at stock height, sits a bit too high for my liking. Front tires are 245/45x17.
    This is with about 1 2/3rd inches cut from coil, stance is good but it's almost too low for going over speed bumps, etc. No rubbing so far.
  4. ProjectCam76
    275
    Aug 10, 2015
    Birmingham, Alabama
    I'm starting to wonder if I should consider the Moog 5608 instead of the 5609's after seeing yours.
  5. KEVS79
    KEVS79 Veteran Member
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    If you search through my build thread you can see my Moog 5664's before and after I cut them. they are pretty stiff, but that helps prevent it from bottoming out that is for sure.
  6. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,983
    10
    May 22, 2001
    Carmel, NY
    Corky, what leaf springs are you using in those pics?
    I have a set of 5610's ready to go in. They are replacing a set of global west springs with a coil cut off. I got tired of the car being "slammed".
  7. ProjectCam76
    275
    Aug 10, 2015
    Birmingham, Alabama
    I'd like to buy a set of Moog to match what your springs look like AFTER you cut them. So then I don't have to do this twice or do any cutting. At least that's my goal...
  8. Orange71
    Orange71 Veteran Member Lifetime Gold Member
    3,792
    Jan 31, 2001
    Finksburg, MD
    Moog 5610 about 1000 miles after install:
    Was too high for me so I cut 1/2 coil off:
  9. KEVS79
    2,465
    Mar 3, 2008
    GLADSTONE, MO
    There is a chart somewhere that compares all the moog springs, I just can find it. Try searching member Todd80Z28. It was on his website.
  10. ProjectCam76
    275
    Aug 10, 2015
    Birmingham, Alabama
    Unfortunately, the link to that doesn't work anymore.
