Cam for a carbed stock Vortec Motor
Discussion in 'Engine Topic' started by 73 DEVILLE, Jun 25, 2007.
  1. 73 DEVILLE
    73 DEVILLE Member
    38
    Mar 27, 2006
    Windhoek: Namibia
    Hi everybody.
    I have a stock carbed Vortec Motor and now I am looking for a cam that will work with only a Getto grind done on the retainers. I am actually looking for a cam that is at least 224 intake 224exhaust with 106 LSA. My problem is now the lift and the price as well as where to find it. I am actually thinking of CompXE cams. I have a turbo 350 tranny with a shift kit on the motor. Any recommendation is welcome as I need a staccato kind of sound. Lumpy actually. I use the car both on street as well as strip once in a while. Any link will be appreciated.
    Thanks in advace.
  2. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    First off, what's the compression ratio of your engine so we can pick a cam for you.
    What else has been done to it!! Headers, carb and intake, etc...
    Rearend gears and tranny as well as car too.
    pdq67
  3. 73 DEVILLE
    73 DEVILLE Member
    38
    Mar 27, 2006
    Windhoek: Namibia
    Pdq67
    The engine is stock from a 1997 4door 4wD Tahoe. I really dont know the exact compression but I asume 9.4.1 comp. I have short headers on it like block hugerrs. THM 350 tranny and convertor unknown I asume stock. 3.08 limited slip diff and 225/65R14 tires. Eddy performer 750 carb and Performer RPM intake 7116. Stock GM distributor, Spit fire coil and 8.5mm wires. True dual 2inch exhaust pipes with a H. Enlarged the exhaust ports on the heads with a common file.
    Thats basical all.
    Thanking you in advance
  4. rustbucket79
    rustbucket79 Veteran Member
    9,076
    May 29, 2003
    British Columbia, Canada
    If you haven't already pulled the factory hyd roller cam, I would forgo the rough idle and take the killer midrange torque that will help accelerate your relatively mild gearing and low stall torque converter. The trucks that those engines came out of are pretty serious performers for what they are.
  5. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Consider GM's -476 if it is bigger than what you have?
    Flat tappet cam tho..
    24502476 Hyd. - 212/220 - .435/.460 - 112.5 - 350 300 crate motor.
    Otherwise, if it is still a roller cam engine if it was, pick a little-bitty performance roller cam.
    pdq67
  6. fiscus
    fiscus Veteran Member
    264
    Apr 2, 2007
    montreal, qc
    Don't forget you will need new valve springs.
  7. 73 DEVILLE
    73 DEVILLE Member
    38
    Mar 27, 2006
    Windhoek: Namibia
    Hi Gents
    The cam the motor has from factory is Hydrolic Roller cam. Therefore I am now looking for something stronger as in the future I am about to replace the low torque convertor with a 2500rpm one.
    thanking you in advance
    73Deville
  8. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    What's that ZZ? engine smaller hy-roller cam??
    Seem's like it may be a dandy for you...
    Look in my list and pick one!!
    Chevrolet Factory Cam Specs by part number
    Part # Lifter type--duration at .050 In/ex--Lift in/ex--centerline--description
    Small Blocks
    3849346 Mechanical – 346GM/314WBR/304PatK./254/254 - .485/.485 – 114/112 - 327 365HP& Z-28 302
    3863151 Hyd. - 221/221-.447/.447-114/110 - 327-350HP, L79
    3896929 Hyd. - 195/202 - .390/.410 – 112/108 - 327 300 HP
    3896962 Hyd. - 222/222 - .450/.460 – 115/114 - 350 L-46, L-82
    3927140 Mechanical - 257/269 - .493/.512 - 112 - Off Road
    3965724 Mechanical - 262/273 - .488/.509 - 112 - 2nd design road race, short track
    3972178 Mechanical - 242/254 - .459/.485 – 116/? - 70 LT1 360 & 370HP, 71 LT 330 HP
    10134334 Hyd. Roller - 235/235 - .480/.480 - 114 - 350ZZZ and ZZ2 Crate Motor
    10185071 Hyd. Roller - 208/221 - .474/.474 - 112 - 350 345, ZZ3&4 Crate Motor
    10224241 Hyd. Roller - - 92-94 GenII, LT1, 350
    10243779 Hyd. Roller - - 94-96 Gen II, L99 265 V-8
    12370845 Hyd. Roller - 214/224 - .488/.509 - 112 - Off Road, lobe for mech fuel pump
    12370846 Hyd. Roller - 222/230 - .509/.528 - 112 - Off Road, lobe for mech fuel pump
    12370847 Hyd. Roller - 232/242 - .539/.558 - 112 - Off Road, lobe for mech fuel pump
    12551142 Hyd. Roller - 203/210 - .476/.480 - 115.5 - 96 350 LT4 w1.6 roller rockers
    12551705 Hyd. Roller - 201/208 - .447/.459 - 112 - 95-96 Gen II, LT1, w center dowel pin
    14088843 Hyd. - 202/206 - .403/.415 - 115 - 305 HO, 83-86
    14093643 Hyd. Roller - 202/206 - .403/.415 - 115 - 87 350 Corvette, IROC Camaro
    24502586 Hyd. Roller - 218/228 - .525/.525 - - 96 LT4 H.O.T. crate motor, use with 1.6 roller rockers
    pdq67
  9. 73 DEVILLE
    73 DEVILLE Member
    38
    Mar 27, 2006
    Windhoek: Namibia
    Thanks PDQ67 for the reply on my quesstion, sorry for taking a bit too long, but thanks a lot.
  10. scrapmetal
    scrapmetal Veteran Member Lifetime Gold Member
    1,819
    79
    Jul 5, 2007
    Cleburne,Texas
    If you had an hyd I was gonna tell ya that the comp extreme 4x4 cams blow!!
