Cam Selection 327
Discussion in 'Engine Topic' started by Craig01, Jul 9, 2021.
  1. tom3
    tom3 Veteran Member
    13,610
    1,130
    Aug 1, 1999
    ohio
    Stock valve covers won't work with TF heads? Ouch.
  2. 1320feet
    1320feet Veteran Member
    449
    199
    Oct 23, 2019
    Calgary, Alberta.
    Use following link Comp cams 268H and click recommend components. At the bottom are two valve springs. click on the red part number to find spring details.
  3. jp71ss
    jp71ss New Member
    Jun 4, 2014
    Bassett, VA
    rocket dawg likes this.
  4. sandlapper
    sandlapper Veteran Member
    786
    289
    Oct 9, 2020
    SE CSA
    Yup
    Yup
    Yup, Not even the final gen 1e w/ vortecs & roller ... even those are ~80 lb on seat single.
    The two recommended comp single springs ... 981 is their "Z28" ... 983 much the same but higher rate. I'm somewhat surprised comp didn't recommend a beehive as well.
    JMO: When "building" a motor, expect to dry fit/mock up & measure-check for proper clearance; experience will tell you a lot about what'll work & what won't (e.g. dual springs w/ a baby sbc cam). Manufacturers would have to write a novel-length set of instructions & procedures to cover every instance; they'd have to revise their SOP every week as others' latest parts are available. YMMV
  5. rocket dawg
    rocket dawg Veteran Member
    469
    59
    May 5, 2015
    Grand Rapids Mi
    No they wont. You might be able to elongate the holes in the valve covers but then the gasket still wouldnt seal very well. With new rockers and valve covers was an extra $500. $320 for the rollers, close to $200 for new aluminum valve covers.
  6. rocket dawg
    469
    59
    May 5, 2015
    Grand Rapids Mi
    Good info. This will help people looking at Comp cams. I figured out which rockers I used to have. Crane High Intensity roller rockers. They worked fine on my World Products heads, but not on the Trick flow heads.
  7. DennisG
    DennisG Member
    69
    27
    Dec 26, 2016
    A high lift cam caused my rockers to hit the valve covers. So I used two valve cover gaskets with an aluminum plate "glued" between them. problem solved cheaply.
    sandlapper likes this.
  8. need-for-speed
    need-for-speed Veteran Member
    814
    37
    Feb 7, 2003
    Conroe, TX
    Do the 2004R. The lower 1st gear will make it MUCH more fun to drive. I replaced my turbo 350 with a 700R4 and I can burn rubber from here to Galveston LOL.
  9. need-for-speed
    814
    37
    Feb 7, 2003
    Conroe, TX
    are you sure the “inner spring” isn’t a damper ?
  10. hd_cat
    hd_cat Veteran Member
    103
    29
    Sep 6, 2013
    United States
    Sounds like a great starting point, I'd consider the Performer RPM intake manifold and a Holley 670 Street Avenger carburetor. The Comp XE274 Cam would likely top the 268H, A 10" TCI converter would help, as would the 3.42:1 or 3.73:1 differential gears. We have an XE274 cam in our GM Goodwrench Crate 350 with a TCI 10" converter and a TH350 rebuilt with a TCI rebuild kit, and 3.73:1 gears, car is fun to drive and is pretty responsive. I also shimmed the HEI to limit timing variance added an Accel Coil, headers and 3" full exhaust, sounds pretty fierce too! Good luck with your project, and yes, I know what free advice is worth... I'm sure you'll find your way to optimize your set-up!
