Camaro RS LS1 Build Thread
Discussion in 'Project Progress' started by thesalboy, Jun 3, 2017.
  1. sprink
    sprink Veteran Member
    570
    184
    Apr 27, 2008
    ffx, va
    Looks great.
  2. giggity
    giggity Veteran Member
    1,471
    350
    Mar 18, 2013
    Pearland, texas
    Im curious about that...seems that things stick to Epoxy better than paint. Im probably going to paint and clear mine first. Allthough I dont think anyone would notice since im going black
  3. SPG
    SPG Bumblebee Builder
    949
    303
    Sep 1, 2018
    Sacramento
    I would like to know the reason as well, I can't imagine it saves much on materials.
    hot72rod likes this.
  4. hot72rod
    3,019
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    If they skipped there, you better go over the car with a fine tooth comb just to be sure they did not miss anything else.
    giggity likes this.
  5. thesalboy
    thesalboy Veteran Member
    506
    235
    Mar 25, 2017
    Los Angeles, CA
    Communication breakdown. When I visited the shop in January, they had already jambed the trunk, but they had painted body color the lower rear window "trim" that is part of the package tray. I noted on the task list I gave them that I'd painted it satin black and it had to stay that way. During my visit in December, I even had a conversation one-on-one with the bodyman/painter about that very issue - I remember pointing out what was already painted and needed to stay black. I guess it would have been better if I speak fluent Spanish. He didn't understand that what I was referring to was just the "trim" that is visible through the glass, and instead apparently thought I just had some pet peeve about how the window channels had to be black. Whatever, it's got epoxy and satin black urethane on it, and no one will ever see it, so it's fine.
  6. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,577
    1,043
    Mar 27, 2016
    NY
    I know how that language barrier goes, I was telling the guys cleaning a over grown yard that they needed to cut down all the weeds, came back and all the trees and everything was gone, HAA HA
    hubedobeedo likes this.
  7. thesalboy
    506
    235
    Mar 25, 2017
    Los Angeles, CA
    For good measure, I scuffed and brush-painted the window channels with POR15, making sure to cover the tape line to minimize the possibility of water intrusion.
    I've been making progress during the virus crisis. I actually feel fortunate to have this project to keep me busy, and the wherewithal to focus on it.
    First thing I did is cover key areas with Transportwrap to protect the paint.
    I'm happy with how the door handles came out. The aftermarket door latches work well. I'd heard of people having problems, but none so far for me. My originals were toast. Will be starting door assembly soon, finally getting to use all the hardware I had plated.
    Welded up subframe connectors. I will hit those welds with Upol Raptor, along with the underside of the rockers - shop only painted them.
    Went way overboard on the Hushmat, but just couldn't stop myself once I started. Still need to do the roof and trunk.
    Last two weeks have been spent at the dining room table with the AAW harness. Their "instructions" leave a lot to be desired, and I'm thankful for Painless making their installation guide available to all. The labeling on some wires is illegible, and none of their crimps are soldered, but otherwise quality seems pretty good. I had to really tear into the harness given my setup and customizing. For example, I've removed almost all of the wires going thru the bulkhead connector into the engine bay: my battery is in the trunk, my PSI harness handles all engine wiring, and I'm not using factory wipers. I'd be ready to install the harness if my power windows harness were here. Latest from Jabin Wood, aka junkyardZ28find, aka HarnessWorx, is that it will arrive tomorrow, but only time will tell because he won't give me a tracking number.
    Can you find the kitty?
  8. giggity
    1,471
    350
    Mar 18, 2013
    Pearland, texas
    I love the handles.
    thesalboy likes this.
  9. StephenShoubridge
    StephenShoubridge Member
    77
    81
    Oct 20, 2018
    UK
    looking really good, would appreciate plenty of door assembly pictures when you start
  10. thesalboy
    506
    235
    Mar 25, 2017
    Los Angeles, CA
    Shooting Raptor under the car was not fun, but it's done, and I got the rockers too and am happy I did.
    Wired up my Digi-Tails. Really happy with the results. Word of warning: the connector on the outboard LED panels was incorrect on my kit, and I had to shave off 2 of the 3 nibs (to make it match the extension harness single-nib connector) to make the connector work properly. I had to disassemble one tail to fix this, and am really glad I caught it because that lead had backed out and likely would have disconnected itself over time.
    Hooked up my new power probe to a scooter battery to test it out.
