Camaros 78-81 wiring diagram
David Muro
19
Brazil
Hello everyone! I redid the electrical map of the Camaros 78-81, now it is vectorized in Corel Draw, in A2 size. I tried to put the wires in the correct colors, the drawings were done in the best way I understood. I ask that if anyone sees any errors, let me know so that it can be definitive for everyone! My intention is to make a painting to hang in the garage!
Later I will send the final version (best resolution), now it will be attached in .png
30,974
Looks pretty good!
That will make some nice garage art! :cool:
It isn't quite legible in the format used in your post. :(
I have to note... There are differences in the wiring between 78 and 81.
(This appears to be a 78 diagram.)
David Muro
19
Brazil
Hi TM, tks! Yep, I see on Diagram session here (Nastyz28) two other diagrams for 81. Can you tell me if the 80 has any difference over the 78? Did you download the image and open it externally? So you can better use the zoom.
30,974
I tried to zoom in on it but it just gets fuzzy. :(
I can't see enough detail to find all of the differences but I know that a 78 only has one fusible link at the starter/solenoid while 79-80 has two.
(I looked in my Haynes manual to be sure.)
Canadian Barton
377
Alberta
This is awesome, if you do a separate file for the 81 let me know. I would print it off in large format and hang on my wall for sure.
David Muro
19
Brazil
I posted a new link, Twisted_Metal, you can see with details now!
30,974
That looks great! :cool:
Definitely for a 78 but it’s a VERY good diagram.
I would have to compare each circuit and color with my Haynes manual to pick out all of the differences for other years.
(I believe the neutral safety switch circuit also changed for 79-81.)
Nice Work!
