can go faster than 90mph!
Discussion in 'Transmission & Driveline Topics' started by camaro19791000, May 17, 2011.
  1. camaro19791000
    camaro19791000 Veteran Member
    103
    Feb 28, 2009
    El paso Texas
    So I taking a cruise late last night, and i decided to punch it, i got to 90mph and car would NOT! go faster, so let go of the gas and punched it(i know dumb but anyways) it boged once it hit 90?im thinking its the tranny, but idk any ideas?thank in advanced!
  2. garyandcindy
    garyandcindy Veteran Member
    1,649
    9
    Oct 20, 2004
    cumming,ga-usa
    Sounds like a timing or fuel issue to me.
  3. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
    what makes you think the problem is with the transmission? I would also think it is more likely to be engine related, but without more info, it will be hard to speculate. Good luck.
  4. CAMLT74
    CAMLT74 Veteran Member
    102
    Sep 27, 2008
    Fredericia, Denmark
    A stuck one way clutch (stator failure) in the converter would give same symptoms. Do you have strange sounds from converter?
  5. Louich
    Louich Veteran Member
    2,415
    Mar 8, 2004
    Arthur, Ontario
    and what was the rpm
  6. camaro19791000
    103
    Feb 28, 2009
    El paso Texas
    Thanks guys but i found a huge puddle of trans-oil i guess since it was at night i totally missed it, seems to be coming from the front trans seal i guess its coming out!
  7. Mike Busutil
    Mike Busutil Veteran Member
    629
    11
    Oct 16, 2010
    Yuma Arizona
    90 mph is good! The speed limit is 65 mph anyway.... ;)
  8. z28inprogress
    z28inprogress BANNED
    196
    Jul 14, 2005
    Hongcouver bc canada
    how are those 6:38 gears? lol
