Can't find source of skip.
Discussion in 'Engine Topic' started by daddio4048, Dec 12, 2013.
  1. daddio4048
    daddio4048 Veteran Member
    823
    Jan 21, 2013
    Valdosta,Ga.
    Having trouble finding a skip with my 350.Changed plugs,distributor & cap,& wires with no luck.Any possible way I have a valve out of adjustment causing this problem ?
  2. Twisted_Metal
    29,497
    2,393
    It's possible.
    A rocker can be loose enough to cause a miss with no noticeable "tick".
  3. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    ....or it could be too tight
  4. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    Go back and visit your new wires in the dark and watch for lightening bugs under the hood, and see if you need to add some dielectric grease to any of the boots or at the ends at the cap.
  5. Twisted_Metal
    29,497
    2,393
    ^ That's actually what I meant to say.
    :confused:
  6. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    HEI or points distributor? I ask because the rubber washer and carbon button are often overlooked on an HEI system.
  7. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    May want to pay attention to the exhaust, hold a piece of notebood paper up over the end of the exhaust pipe and see if you notice any exhaust pulses going in the wrong direction...if you do notice some sucking back at the tail pipe, you may have an exhaust valve not sealing(rocker too tight) or an exhaust valve could be could be burnt.
  8. daddio4048
    823
    Jan 21, 2013
    Valdosta,Ga.
    Rubber washer on HEI ?
  9. Damon
    Damon Veteran Member
    12,939
    23
    Nov 16, 2000
    Philly area
    Also check compression on that cylinder. If it's way down you've got a rocker adjusted down too far OR mechanical damage of some kind in that cylinder.
  10. ol' grouch
    ol' grouch Veteran Member
    3,623
    1,147
    Jul 4, 2013
    Evansville, In.
    I've had engines that had a minor....blip, that I just couldn't get out. I replaced the cap and rotor with "Blue Streak" parts. I think Standard makes them. They have brass inserts and will give just the little bit better conduction. Normal caps and rotors often have aluminum contacts.
