Can't find source of skip.
Discussion in 'Engine Topic' started by daddio4048, Dec 12, 2013.
  1. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
  2. middleagecrisis
    middleagecrisis Veteran Member
    967
    Oct 22, 2007
    I've had this issue and went through all the same troubleshooting tips listed above. It turned out to be a worn bushing in the distributor housing, causing erratic timing (dwell) at a steady rpm. Just another possibly culprit for you to consider. How old is your distributor?
  3. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    Accel makes a decent cap also and has the brass terminals and a rotor button with a brass tip.
    Those aluminum terminals corrode pretty easy when in a damp environment.
  4. COPO
    20,782
    2,403
    NAPA sells the parts with brass connectors and they seem to last longer.
  5. ol' grouch
    ol' grouch Veteran Member
    3,623
    1,147
    Jul 4, 2013
    Evansville, In.
    Something I just remembered. I got a car in the shop once that had a new cap and rotor but would cut out at certain speeds. It turned out that the spring on the center electrode was bad and would let the contact bounce off the rotor tab.
  6. muscl car
    23,229
    1,668
    Jul 8, 2001
    SoCal High Desert
    are you running a ignition box ?????
  7. daddio4048
    daddio4048 Veteran Member
    823
    Jan 21, 2013
    Valdosta,Ga.
    I was told by Holley today that I might have the wrong power valve in the carb.Got to check vacuum & see how much it's pulling.
  8. daddio4048
    823
    Jan 21, 2013
    Valdosta,Ga.
    I either have a valve not seating correctly or I have a plug that is missing intermittently. I running A/C Delco #2 plugs. I took them out & they all look like they are firing just fine. No black tips. The only thing that has not been changed is the plug wires.They are the NAPA premium 8mm wires.This is driving me insane trying to find this issue !
  9. markw
    markw Veteran Member
    820
    Jun 6, 2009
    Illinois
    A few specifics are needed. When does it skip? What are you doing with the throttle to make it skip? At what rpm does it skip? What is the vacuum level when it skips? Does it go away if you give it more throttle? Is the engine fully warmed up? What is your timing curve? Vacuum advance specs? What are your engine specs? What cam? What carb? What is a "A/C Delco #2 plug"?
  10. troutman
    troutman Veteran Member
    121
    Mar 16, 2009
    Chapin,S.C.
    Check to see if you have crossfire on spark plug wires #5 & #7.
