For quite some time I noticed the high idle cam was intermittently working on my Eddy 1406. It was more annoying than anything, and not really a big deal, just pedal the throttle until it gets warmed up. I took the carb off to clean it for the winter, and realized that the high idle cam itself was sloppy on the shaft it was on, and sometimes not actually centered on the screw, and slipping off. I made a washer about .040 thick, and inserted it to take up the slop. During the course of time, the screw end got rounded over a bit. Got that squared away, and filed the steps a bit sharper on the cam as well.
The spacer/washer is made out of white delrin, simply because that what I had laying around. If anyone else does this, just make certain not to make it woo wide, and bind up the secondary blade lockout. Hope this maybe helps someone else out as well.
Below is the underside of my carb as it sits on the idle speed screw. You can see the "transfer slot" is exposed at idle. I know that it shouldn't be that way. As expected, the idle air/fuel adjustment screws seem to not make any change. If I lower the idle speed, it stalls forcing me to keep it there. I'm thinking that I should chose a metering rod that is smaller in diameter for the jet that it sits into. This should flow more gas at idle, then maybe I can turn the idle speed screw in enough to get it off of the transfer slot. Is my thinking right on this? The choke seems to be set correctly, as I have had no issues with it's function. The cam has a bit of a thump to it...vacuum is a bouncy 14 at idle, then vacuum goes solid to 20 at about 2000rpm.
