Carb Metering Plate Question
Discussion in '1970 - 1973 Specific' started by bkmont, Aug 26, 2021.
  1. bkmont
    bkmont Veteran Member
    1,299
    166
    Nov 14, 2010
    Pensacola, Florida
    What purpose does the plastic piece serve in this metering plate?
  2. CorkyE
    11,434
    935
    Helps prevent fuel slosh out the vent tube.
    2ndGenCrazy likes this.
  3. COPO
    21,199
    2,671
    Most Holleys have this type.
  4. bkmont
    1,299
    166
    Nov 14, 2010
    Pensacola, Florida
  5. G72Zed
    G72Zed Veteran Member
    3,322
    1,763
    Sep 8, 2015
    I have seen COPO's small angle baffle style on many OEM and older model OEM replacement carbs, and on most all with side hung floats, Holley # 85-626, but are plastic instead of the brass I believe. The screen version works well in this case, Holley # 26-39
    All the quality center hung bowls use the better designed extended baffle #26-89, the billet metering blocks use the #59-10, no drilling for the knurled pin.
  6. Romney Mawhorter
    Romney Mawhorter 70½ Z/28 RS, M21, 4.10, 65k/71 Restomod SS396
    47
    Feb 21, 2021
    Southern California
    Kickstand for working underneath it when you take it out?
