Carbon Fiber or no?
Discussion in 'Body Restoration' started by phantom69, Feb 15, 2021.
  1. phantom69
    phantom69 Member
    37
    Dec 16, 2020
    just throwin it out there what are some thoughts on a carbon fiber hood and trunk lid combo on a first gen? with all the "so long as its the same color as the car" arguments are fulfilled
  2. badazz81z28
    20,929
    1,467
    Alabama
    Waste of money...the panels are very expensive and don’t fit. You gain nothing in your street car unless you are simply going for the look. Expect to spend thousands and still have to body work them to fit.
  3. TTR230
    TTR230 Veteran Member
    512
    261
    Aug 1, 2020
    Burlington, Ontario
    This^. Carbon fibre on almost all road cars is a waste of time and money. However, when has that ever been a barrier to doing something we want to do, lol? It's your car, do what you want. But it is only for looks, and maybe only on a "restomod" type car. Also, on most carbon fibre, the beauty of the finish is so fragile, even for a Sunday driver if you're "fastidious".
  4. Zspoiler
    Zspoiler Veteran Member
    4,054
    465
    May 6, 2012
    Federal Way, Washington
    For the street fiberglass and or steel is better .And a whole lot less expensive ,Carbon Fiber is more for race cars ,for weight purposes.
  5. badazz81z28
    20,929
    1,467
    Alabama
    Coming from me who has a DSE catalog Camaro...a $2500 hood that’s not bolt on it outlandish. I would probably do it if they had the cowl vents and didn’t have to body work it to fit right.
  6. G72Zed
    G72Zed Veteran Member
    3,039
    1,512
    Sep 8, 2015
    Here's a good test, bolt on 2x 20lbs lead bricks in your engine compartment, like brackets above the upper A tables, cyl. head height, make some passes/runs/laps and look at the time reductions.
    This will tell you approximate ROI be it a CF hood or Aluminum heads! Sometimes costs for entry does not make sense. Take the same bricks and bolt them in the rear/trunk, do the same thing, may tell the story of what is needed vs wanted.
  7. COPO
    21,040
    2,581
    Why is the question.
  8. TTR230
    512
    261
    Aug 1, 2020
    Burlington, Ontario
    I completely agree, for a race car, but even then, they're is lots to do for weight reduction first for a much lower cost. I'm not sure the op is looking for the equivalent of that last few horse. For a street car, it's cheaper to lighten the car by driving around with a quarter tank of gas instead of a full tank. It's just looks otherwise. I understood that if you take care of the ounces, the pounds take care of themselves, but back when I was racing motorcycles, it was dead easy to spend hundreds and even thousands on ti and carbon, etc, but at my skill level, it was academic anyway. Four pounds wasn't making the difference. I gained that in a few daysif I wasn't watching my diet!
  9. badazz81z28
    20,929
    1,467
    Alabama
    I will say, a quality CF hood would save you some poundage, but I don’t think the trunk lid is really that heavy, plus you want some weight back there. Gosh a CF trunk lid is $1200!!
  10. DB Z28
    DB Z28 Veteran Member
    646
    98
    Nov 30, 2003
    Fond Du Lac
    If its made by Anvil its make in China
    badazz81z28 likes this.
