carbon mixed with water out of tailpipe at cold start
Discussion in 'Engine Topic' started by pomartin, Oct 17, 2020.
  1. pomartin
    pomartin Member
    90
    Sep 16, 2019
    Dear all,
    I have yet another issue I'd need some advice for.
    When the car is cold and started up, there is quite some carbon mixed with condensed water coming out of tailpipe. I'd like to get rid of carbon, I'm getting a bit tired of cleaning garage after every startup :p
    When I bought the car it was running extremely rich, there was a lot of carbon deposits on heads, pistons and tailpipe.
    Now after few thousand miles running with AFR 14-15 when cruising combustion chamber is quite cleaner- carbon seems to be slowly burning up.
    Tail pipes are still black. Valves are nice and clean.
    Operating temperature is about 175f
    Is there any non-mechanical DIY way to clean the carbon up a bit?
    I've read about spraying isopropil-alcohol mixed with water into the carb, but never found good instructions regarding mix % for it.
    Anyone used seafoam or similar?
    How about spraying just pure (de-mineralized) water?
    Or perhaps feeding any of the above through carb vacuum port during load?
    EDIT: engine has a blower if it means anything
    Any tips or tricks are welcome :)
    Thank you in advance,
    Martin
  2. biker
    biker Veteran Member
    2,170
    798
    Dec 7, 2014
    Mine did that too for a while after a bit of a rich spell with the carb. It disappeared once the carb was dialed in. Just could be lots of carbon in the exhaust.
    I've dumped all kinds of stuff into carbs to clean carbon. A gm dealership I worked at in the 80's used to regularly de-carbon engines by dumping water in them. Engine idling, slowly pour water into carb while working the throttle by hand to prevent stalling. Fascinating to see as a kid. Some mechanics would get quite aggressive with it, holding throttle way open and dumping water in, enormous amounts of crap flying out the exhaust. Every single one ran better afterwards though. Apparently the water cools carbon deposits, making them pop off metal surfaces.
    I do not recommend it for an engine you care about though. And I dont know if it would help you since your engine is already pretty clean.
    carhead22000 likes this.
  3. Gary S
    23,441
    1,298
  4. Twisted_Metal
    28,305
    1,692
    Even with a clean engine... Getting it all out of the exhaust will take time.
    Meanwhile.... Put a big piece of cardboard under the rear of the car to catch the water/soot to keep it off your garage floor.
  5. Jodi
    Jodi Veteran Member
    492
    263
    May 22, 2019
    A nice long spirited drive on the highway with varying load on the engine.
  6. muscl car
    22,800
    1,388
    Jul 8, 2001
    SoCal High Desert
    I still do that de carbon trick but use a spray bottle filled with water . I high idle the engine then spray water into the carb
  7. sandlapper
    sandlapper Member
    69
    18
    Oct 9, 2020
    SE CSA
  8. COPO
    19,495
    1,593
    Go for a drive and hammer it through the gears 5x’s to redline, it’ll clean your plugs and combustion chamber. I use Seafoam in the gas tank and also sprayed it using a sprayer you add air too. As well as Marvel Mystery Oil in the gas tank, just follow the directions per tankful of gas.
    I’ve also used GM Cleens religiously since the 70’s.
  9. pomartin
    pomartin Member
    90
    Sep 16, 2019
    Thank you all for your input.
    I'll first try to get some more serious mileage on the highway, where I can performs pulls more often.
    Then I'll try water or seafoam.
  10. COPO
    19,495
    1,593
    At a certain temp, your spark plugs enter the self cleaning mode while driving on the highways. But several stops and hammering it through the gears will also clean your plugs.
