Carburetor back fire
Discussion in 'Troubleshooting & Diagnosis' started by Justin79maro, Apr 10, 2017.
  1. Justin79maro
    Justin79maro Veteran Member
    273
    11
    Jan 15, 2015
    Bonne terre, missouri
    I'll swap it out with one I have, it is also a new plug wire... things arnt going to well for me lol
  2. 496z28
    496z28 Veteran Member Lifetime Gold Member
    967
    8
    Sep 23, 2007
    Oklahoma City
    Flat cam lobe.
  3. Justin79maro
    273
    11
    Jan 15, 2015
    Wit
    with a hydro roller cam?
  4. Justin79maro
    273
    11
    Jan 15, 2015
    It idles just fined, might sound a little different then before
  5. Bandit723
    Bandit723 Veteran Member
    3,655
    674
    Oct 1, 2016
    Waupaca WI
    Well this is a start i would start chasing down the cheap obvious. swap a plug wire any change with the timing light?, pull the plug check to see if it is fouled, pull the dist cap see if there are issues there "have seen a cracked cap cause havoc on how an engine runs". As to a dead cylinder i personally have not seen any backfire issues even on my current car had number 7 plug wire come loose there was a bit more shaking to the engine and when you got on it it blew out some gray smoke.
  6. jimrr
    jimrr Veteran Member
    1,334
    307
    Jun 12, 2016
    sarasota
    The fuel spitting up thing.......check your fuel pressure. If it's really high its going to push fuel right past everything inside your carb. Keep it simple.
  7. Justin79maro
    273
    11
    Jan 15, 2015
    It's coming out of the carb on the driver side bank, and I put in new plugs. Check the cap and rotor and the wiring
  8. cadillac_al
    cadillac_al Veteran Member
    1,013
    145
    Apr 22, 2015
    Maine
    Just my .02 but i would 2nd the broken valve spring possibility.
  9. Justin79maro
    273
    11
    Jan 15, 2015
    Well I check the springs and rockers again and everything looked fine. It's got like a air clicking noise coming out of the carb on idle but it revs fine and it still pops has out of the carb when you rev it up
  10. MotionClone
    MotionClone Veteran Member
    1,479
    303
    Jan 20, 2014
    away from the crazies
    how is your accelerator circuit? All working fine?
