catalytic converters
Discussion in 'High Performance Modifications' started by john77, Jul 5, 2010.
  1. john77
    john77 Member
    32
    Nov 10, 2009
    bogalusa,La
    Ok, I know that catalytic converters are like taboo to high performance engines, but I was wondering if anyone has used any of the high flow converters. I have a 350 horse 350, with headers and a 675cfm holley, I'm not going to be doing any racing, just cruising. I wonder if I used some converters if it would cut down on some of the exhaust fumes. Anyway, dont hate me, I'm just kinda thinking out loud.
  2. li0nhart123
    li0nhart123 Veteran Member
    737
    Jan 20, 2008
    British Columbia
    If you are burning too rich or are burning oil, you will plug the cats. your engine has to be in good shape to use them.
    I've seen people remove the cats and have their engines run worse...back pressure, sensors. etc.
    In general, they do restrict flow, I wouldn't expect to gain anything by adding them.
  3. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,116
    49
    Sep 22, 2007
    Blind Bay, B.C.
    I too have been thinking of getting cats. just to pass emmissions. My engine is tuned and not burning oil. Anybody care to elaberate on this issue?
  4. Randy 81
    Randy 81 Veteran Member
    938
    20
    Oct 28, 2009
    Loganville, Ga
    Definitely work on the tune, otherwise the converter will get plugged up. If it is tuned right, the fumes shouldn't be bad at all.
  5. john77
    john77 Member
    32
    Nov 10, 2009
    bogalusa,La
    the engine runs great at wot and idles great, its just at idle after sitting still for a while you can smell exhaust fumes some, not bad but more than a modern car with cats. What would be the best way to tune the carb, maybe a a/f ratio monitor or what?
  6. ULTM8Z
    ULTM8Z Veteran Member
    9,835
    767
    May 19, 2000
    Los Angeles
    I'm running hi-flow cats on my car. Had them on for about 7 years now.
  7. tom3
    tom3 Veteran Member
    13,202
    881
    Aug 1, 1999
    ohio
    The newer cats have a ceramic block with a million or so holes and the catalyst material seems to be small flakes embedded in it. I don't know for sure but I suspect these are pretty tolerant of rich mixtures unlike the older factory style converters. Be worth a try. But be careful of the placement of the converter, they get really hot and can cause big trouble if too close to the floor.
