CDs sticking
Discussion in 'The BS Topic' started by bfmgoalie, May 22, 2020.
  1. bfmgoalie
    bfmgoalie Veteran Member
    2,198
    559
    Jun 14, 2008
    Gansevoort, New York
    Every now and then, I'll pop a CD in and it sounds like its stuck...plays the same portion for like 10 seconds. Anyway to stop that from happening?
  2. Knuckle Dragger
    15,547
    1,965
    Nov 2, 2002
    Waddell AZ
    Clean the CD, check for scratches.
  3. Gary S
    22,987
    1,039
    CD players like all consumer electronics today are very difficult to have repaired. Usually, the best solution is to replace the unit with a working one.
  4. dave@ztech
    3,917
    840
    Mar 27, 2016
    NY
    Make sure the lotion is not on your hands when putting in the next XXX movie, HAA HA , fingerprints and dust will foul them up, also clean the tray that you put them on as well.
    Zstar likes this.
  5. COPO
    18,820
    1,216
    Buy a CD cleaner disc that you play in the machine.
  6. Lowend
    15,315
    626
    Mar 25, 1999
    San Jose, CA, USA
    Scratched CD's are common.
    Use some toothpaste and your finger to polish the surface. Rinse it with water, you won't hurt it, and blot dry.
  7. Phil G
    Phil G Veteran Member
    763
    54
    May 3, 2004
    Tucker, GA, USA
    I was taught to handle vinyl records by the edges when I was a little kid. Pop was very particular about his records and sound system (early '60s). I still don't fingerprint discs of any kind. What I have had good luck with when I rented DVDs and they were almost invariably scratched was to use Zymoil. Worked every time. Wipe on, polish off, yer done...
