Center dash speaker mount and year models???
Discussion in 'Car Audio, Electronics & Security' started by Popper, Mar 19, 2020.
  1. Popper
    Popper Veteran Member
    101
    13
    Mar 24, 2018
    Does anyone know if the center dash speaker mount is the same for all 2nd gens? My car does not have a speaker or a mount however i can get one from a fellow member that has one from a 70, my year model is a 79.
    I got the itch to redo my stereo after reading some posts. I am doing away with door speakers and relocating them to some kick panels either pre-made of i'll make them myself. I would like to do some center fill with the dash speaker location.
  2. Twisted_Metal
    27,680
    1,300
    My 80 had a round speaker magnet and the bracket looked a little different. (The magnet clips into the bracket.)
    But I think that was a change just for 80-81 models. They also used an aluminum bracket, IIRC.
    70-79 model speakers used a rectangular magnet and a steel bracket.
    Are you replacing the front speaker with an aftermarket unit?
    If so... some of them come complete with the mounting bracket.
    If you're gutting the old speaker and fitting two 3-1/2" or 4" speakers into it, you need to look at your factory speaker to see what shape magnet it has.
    Search ebay for "Camaro Front Speaker Bracket"...You will see two different brackets.
    Short answer... I believe 70-79 uses the same bracket.
    Popper likes this.
  3. Pierre74LT
    Pierre74LT New Member
    25
    Dec 28, 2012
    Qc
    my 74 has the same bracket
  4. Popper
    101
    13
    Mar 24, 2018
    I ended up with custom mount of the original along with custom bent abs, turned out pretty nice
    NOLAZACK likes this.
