Ceramic coated vs. Jet Hot coated headers
Discussion in 'High Performance Modifications' started by moemills, Sep 12, 2006.
  1. moemills
    moemills Veteran Member
    138
    Feb 25, 2002
    Laguna Niguel, CA. USA
    Are there any beneifts / detriments of using either one? I have seen the JeT Hot headers at a lower priced then the vendor ceramic one. I'm curious about the durability of both - are they equal.
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    Jet Hot is ceramic coating.
  3. Badkarma
    Badkarma Veteran Member Lifetime Gold Member
    1,028
    Mar 27, 2002
    stanton ca usa
    I belive he wanted to know if jet hot is a better quality coating than what, lets say, a set of hookers would come with when ordered coaterd with Hookers ceramic coating. I have often wondered if one companys end product was better than another, of if it mainly came down to who had better customer service.
  4. 79silverz28
    79silverz28 Veteran Member
    726
    Jan 6, 2006
    Texas
    Good question...
    That's a really good question, but I think in general Jet Hot is probably just doing more volume and so able to get a better price. I have had 3 different cars with ceramic coating, all three by different companies [Jet Hot, Hookers with the coating on it already, and a local shop that did ceramic coatings] which each lasted me 10 years on the car with almost no issues [the edelbrocks started to get some spots on them after 10 years of being outside and in a wet north eastern US part of the country].
    So, my general answer answer is get whichever you want. My cautious answer is to get something like the JetHot 2000, which I think has a lifetime warranty. Then you can always pull them off in 10 years, and mail them back. I've known a couple of people who have pulled them off after 5-6 years and mailed them in just as preventitive maintenance, and Jet Hot recoated them for free.
    Anyway, I don't think you can really go too wrong with coating, or I have been very lucky :)
  5. moemills
    138
    Feb 25, 2002
    That was my question ... is one better than the other cause I can get the Jet Coat cheaper.
    After I posted this I called Summit. They don't sell the Jet Coat headers (only Ceramic from the manufacturer). But they told me they believed that Jet Coat did both the inside and outside of the headers and the Manufacturer only did the outside. ????
    Thanks for all your input.
  6. Ztoy
    Ztoy Veteran Member Lifetime Gold Member
    3,932
    May 4, 2003
    Ionia, Michigan
    Ask anyone selling ceramic coated headers and they will tell you theirs if the best. Personally, imho, they are all pretty much the same. The diff is probably going to be the quality of their work and their service if there is a problem.
    I called Jet Hot and ordered a set of Super Hookers with their coating inside and out which is guaranteed for life. I received the headers and upon further inspection found the packing was not up to snuff which allowed the collector from one header to rub one of the tubes from the other header.
    This went through the coating, so I called them. They sent me a call tag for the old headers, and I recieved a new set within 5 days, not the same set recoated. Now thats service if you ask me. This will make me buy from them again if ever needed. Btw, the 2nd set was perfect......
  7. 1978LT
    1978LT Veteran Member
    16,280
    Feb 24, 2002
    Poquoson, VA USA
    Man, I don't know if I'd even be sure of that, if the coating rubs off that easy. I figured ceramic was mega tough stuff??
  8. Gary S
    22,961
    1,027
    Remember that ceramic is glass. Anything hitting against it will break it, and here in the frozen North, just starting up an engine on a very cold day when the headers are wet with snow will break the glass and it will start to fall off the first Winter.
  9. 77thor
    77thor Veteran Member Lifetime Gold Member
    2,781
    21
    Mar 22, 2002
    Milwaukee, WI USA
    I would want the inside and the outside coated... so I would buy directly from Jet Hot
  10. Transman
    Transman Veteran Member
    279
    Waterloo, Iowa USA
    I'm quite happy with my NitroPlate coated Dynatechs.... great finish work and reasonable pricing. Excellent service as well. Here's a shot of them with the motor out of the car:
    (Motor now has a little different look to it.... if anyone is looking for a 750 Demon let me know... hint, hint!)
