Champion or MSD Wires- Poll Time
Discussion in 'Engine Topic' started by ratpatrol71z28, Nov 6, 2016.
MSD or Taylor Spark Plug Wires?
  1. MSD
    89.5%
  2. TAYLOR
    10.5%
  1. ratpatrol71z28
    ratpatrol71z28 Veteran Member
    1,577
    Mar 29, 2012
    Mantweeka, California
    Hey guys, I am looking to order some new wires for my mild SBC...
    I know these are both good brands. I have ran MSD Streetfighters before and they seemed to work good. I also heard good things about Taylor Wires as well. So give me your inputs on each or other possible candidates... Any benefits from the 10.2mm vs the smaller 8mm?
    Thanks everyone!
  2. ratpatrol71z28
    1,577
    Mar 29, 2012
    Forgot to mention I am running full MSD ignition set up... Distributor, coil, and spark box.
  3. COPO
    20,586
    2,304
    Get wires that give 40 ohms/ft of resistance.
  4. ratpatrol71z28
    1,577
    Mar 29, 2012
    Less ohms the better, right?
  5. CorkyE
    11,257
    851
    Yes, less ohms (resistance) is better. These are measured per foot, so a 2 ft wire will have twice the resistance. I've used both Taylor and MSD spiral core wires and had good luck with both. I'm currently using MSD 8.5 Super Conductor wires because the boots seem to be more sturdy.
  6. Zspoiler
    Zspoiler Veteran Member
    3,937
    416
    May 6, 2012
    Federal Way, Washington
    i have run MSD 8mm wires for a long time. I have tried other wires over time .But I have had the best luck with MSD`s
  7. Lowend
    16,235
    1,164
    Mar 25, 1999
    San Jose, CA, USA
    I've seen many many wiresets, nothing is better than the MSD Superconductors
    Low Ohm/foot, good insulation, double crimp connectors
  8. ratpatrol71z28
    1,577
    Mar 29, 2012
    Thanks for your input!
  9. camaro71/holland
    1,480
    192
    Aug 27, 2003
    The Netherlands
  10. carr911
    carr911 Veteran Member
    3,492
    3,383
    Mar 4, 2016
    Tampa, FL
    I use MSDs with no problem. In my opinion, if you are using MSD components, use their Wires!
