Change trans fluid and filter? 95 Z71
Discussion in 'The BS Topic' started by JWZ28, Mar 31, 2014.
  1. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    I recently inherited my grandpa's 95 Z71. I've been doing the regular tune up stuff on it and was about to do a trans fluid and filter change. I know for a fact it's never been changed and the truck has 115,000 miles. Trans fluid is a dark reddish brown and trans still shifts great. No burnt smell.
    I've heard that changing the fluid and filter can actually cause the trans to slip and fail if it hasn't been changed regularly. Anyone have any input here before I go ahead with the fluid change? I'm not doing a flush, just draining the pan, filter change and refill.
  2. sal70ss
    sal70ss Veteran Member
    2,023
    1,010
    Jan 31, 2003
    Auburn NY
    I never heard of a such thing. Changing the trans fluid and filter Is good maintenance..
  3. Knuckle Dragger
    16,566
    2,892
    Nov 2, 2002
    Waddell AZ
    I'm sure you'll get opinions all over the spectrum here, but I wouldn't change it.
  4. Gary S
    24,133
    1,639
    I did have a transmission fail the day after changing the fluid, but I don't think changing the fluid had anything to do with the failure. The tranny was shot before the fluid change.
    Some years ago I bought a used car with one of those magic TH200 trannys. Knowing what they are, I had my Son change the oil before we drove it far. He found chunks of clutches in the pan, and the fluid was badly burned. The next day, we took the car on a 100 mile run. By the time we got home, it was barely able to move under its own power. The tranny was basically dead in both forward and reverse. I took it to a tranny shop and replaced the TH200 with a TH350. End of problem.
  5. LADDTWZ
    LADDTWZ Veteran Member
    577
    41
    Aug 11, 2012
    Schoolcraft, Michigan
    My '02 GMC had 140K on it. Changed the fliud in the tranny, and yup, junk. no issues before. Literally right after fluid change change, it would not move.
  6. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    hmmm.... I may just leave it.
  7. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    Every time I've changed fluid in a high mileage vehicle, seems they've given up on me. I did just swap a used trans in my GTP - I changed the filter and fluid in it, seems fine. I did read that you should just change it, but not flush it, and do not change to synthetic. I didn't help you much, could go either way, lol.
  8. Mike N
    3,012
    740
    Jan 13, 2002
    Spencerport, NY.
    I wouldn't have a problem changing it. If it gives up after the fluid/filter change it was junk anyway.
  9. nikogto
    nikogto Veteran Member
    205
    Sep 6, 2012
    mooresville, north carolina
    If you don't flush the trans fluid out after changing the filter you're wasting your time mixing all the old fluid in the torque convertor and lines/cooler. If you don't have a flush machine to use, go to a shop that does or they have some vids online on how to do it yourself. We usually flush 12 qts. through them
  10. Joekool
    Joekool Veteran Member
    5,924
    36
    Feb 4, 2002
    Hollister CA USA
    The ones that usually fail after a service are because the people knew in the back of their mind that the trans was having issues and they somehow thought a new filter and some fluid would fix it.
    Plus seeing what is in the pan will tell you a lot about the condition of the trans.
