Changing over from auto to 5 speed
Discussion in 'Project Progress' started by joer, Nov 23, 2017.
  1. joer
    joer Veteran Member
    245
    Sep 25, 2008
    East Brunswick, New Jersey
    Finally finished the job. What a pain in the rear. Here's some before and after pic's.
  2. jimrr
    jimrr Veteran Member
    1,334
    307
    Jun 12, 2016
    sarasota
    Looks fantastic!
  3. Green hornet
    Green hornet Veteran Member
    2,028
    478
    Oct 11, 2015
    North Bay, CA
    Nice work. How does the car feel with the new trans?
  4. COPO
    21,095
    2,616
    I can imagine the work. I know the work I put in when I
    R&R my Muncie, clutch kit and flywheel with no lift in my 60’s. It’s still not a big deal since I still workout, bike, ski, golf and have a workout in bed.
  5. joer
    joer Veteran Member
    245
    Sep 25, 2008
    It feel's good. Car pull's hard through the gears. Still running 4.10's. 5th calms the car down. Good for cruising. What a difference.
  6. joer
    joer Veteran Member
    245
    Sep 25, 2008
    I'm 63. The hardest thing was putting in the pedals.
  7. czizza
    czizza Veteran Member
    1,131
    118
    Jan 8, 2004
    N. Massapequa, NY, USA
    You are gonna love it more and more each day ... No pain ... No Gain.
    What was the hardest part?
  8. joer
    joer Veteran Member
    245
    Sep 25, 2008
    Putting in the pedals. Had to take out the steering column and squeeze under the dash.
  9. czizza
    1,131
    118
    Jan 8, 2004
    Ah ... If you ever do this again ... simply unbolt the old brake pedal via the shaft bolt and then slide in the manual setup and re-connect the shaft bolt. It saved me a ton in the old days.
  10. joer
    joer Veteran Member
    245
    Sep 25, 2008
    Thank's but I'm pretty sure it's my LAST TIME.
